Thread: seat toledo 1.9tdi 2006 reg fault code p0237
  1. seat toledo 1.9tdi 2006 reg fault code p0237
    Sep 2009
    Limerick . Ireland
    Working on a 2005 toledo 1.9 tdi . no power in car . showing fault code p0237 turbo boost pressure low . changed vacuum solenoid , no difference. changed map sensor , on difference, .I have no pressure on turbo pipes when revved. also no vac pressure at turbo wastegate activator. no leaking pipes found. thank you
  2. Re: seat toledo 1.9tdi 2006 reg fault code p0237
    boustie Guest
    must be an air leak or faulty boost pressure control solenoid
  3. Re: seat toledo 1.9tdi 2006 reg fault code p0237
    46 Post(s)
    im sure after 1.5 years its been sorted .. please stop bumping old threads
  1. Golf MK5 1.9TDI Fault Code P0299 +P0401
    By browser1 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-11-2010, 04:35 PM
  2. Please Help Seat Belt Pretensioner Fault Code
    By taff111 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-09-2010, 03:33 PM
  3. seat leon fault code 16947 system voltage too high?
    By yas_b in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 30-03-2010, 11:37 PM
  4. Replies: 0
    Last Post: 22-03-2010, 12:32 PM
  5. Fault code on mk4 auto 52 reg 1600cc
    By golfs and stuff in forum Golf MK4 - 1999 - 2004
    Last Post: 05-02-2008, 08:08 PM
