Thread: Central Locking problem - Defective door locks
  1. Central Locking problem - Defective door locks
    Mar 2011
    London
    1
    Central locking problem.
    Hi.
    I have an Audi A6 Allroad 2.5 tdi,2001.I bought yhis car as a stollen recovered.There is a problem with the central locking.The problem is that the only door that opens with the door key, is the drivers door.The rest of the doors stay closed.Even with the drivers side open switch button pressed they still do not open.The keyfob also does not work,i have changed the batteries.When i Disconnect and connect the power supply to the central locking control module that sits inside the passenger footwell and switch on the ignition and then press the door open switch on the drivers side door,the doors open,but once i close the door from the outside wth the key in the door lock and then immediatley open the door,only the drivers door opens,the rest stays closed and wont open from the inside.
    i had a diagnostic bloke round,and his computer came up with the following codes:01374:Alarm triggered by terminal 15.
    Code:01559rivers door,59-00 can't unlock/60-00 won't save.
    When the guy cleard the codes from his pc,and then closed and opened the front door from the outside the fault codes came back
    Can someone advise me on what to do next?
  2. Re: Central Locking problem - Defective door locks
    1
    Check all connectors inside the A and B pillars. There are two in each at the pillar end not the door.
    If all is well, remove the passenger kick panel and lift the carpet to see if all is dry and all the cable harnesses and connector to the CCM are free from corrosion.
    Regards Peter
  3. Re: Central Locking problem - Defective door locks
    Mar 2008
    High Wycombe
    71
    The keyfob often needs reminding that it works after you've changed the batteries:
    Lock the car
    push the unlock button once
    manually unlock the car within 30 seconds
    Now the fob should work.
    If it still doesn't, then the keys might need recoding - there's plenty of threads on this section where Peter D has posted the instructions.
    Normally, turning the key / pushing the fob once will only unlock the driver's door. Turning the key/pushing fob a second time will unlock the rest of the doors. This is a security feature to stop a passer by from hijacking you as you get in (or it's just to annoy my wife)
    Regarding the fault codes, I second Peter's advice.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: Central Locking problem - Defective door locks
    Mar 2011
    London
    1
    Hi ti everyone.
    And thanks for all the replies.
    I've already checked the ccm box and there was some corrosion to the black power connector,and the yellow connector that runs the alarm.The passenger footwell was dry though.
    Tried all the means possible to try and manually code the keyfob to the car,but still the doors don't open with the key fob.
    Going back to the central locking problem.It seems that the alarm is permernantley on,thats why i think the doors won't open manually,but the car starts.
    Does anyone knoe a good auto electricion in the london area,preferably close E16 3ts, post code?I really need to get this car fixed!!!
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2014, 12:19 PM
  2. Audi 80 Central Locking Problem
    By tp5harp in forum 80 - 90
    Last Post: 20-05-2010, 09:30 PM
  3. Central locking problem
    By desparate22 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-05-2010, 06:57 PM
  4. Please Help Central Locking Problem
    By ghowe79 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-03-2010, 10:40 AM
  5. Please Help Central Locking Problem
    By MBEN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-03-2010, 08:48 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
