Hello.
I am hoping somebody on here with a little knowledge of VCDS could explain the before and after data readouts that were taken before and after a dsg basic settings was performed on the car as it doesn't mean much to me lol. Is it better or worse ? Trying to work out what the minus numbers mean?
Before:
14:42:23 Group 006
P Selector Lever Position
0.000 A Valve current clutch valve 1
18.0 % Safety valve 1 (N233)
0.840 A Main pressure valve current
14:42:26 Group 007
0.000 A Valve current clutch valve 2
18.0 % Safety valve (N371)
14:42:33 Group 010
0.0 % Accelerator pedal angle
Kick-Down switch
-6.0 Nm Engine torque
51.0 Nm Engine torque (loss)
14:42:41 Group 013
0.000 A Solenoid current clutch valve 1
18.0 % Safety Valve 1
0.0 % Solenoid Valve 1 (N88)
0.0 % Solenoid Valve 2 (N89)
14:42:45 Group 014
0.000 A Solenoid current clutch valve 2
18.0 % Safety Valve 2
0.0 % Solenoid Valve 3 (N90)
0.0 % Solenoid Valve 4 (N91)
14:42:50 Group 015: Gear Selector
519 Gear Selector 1-3
281 Gear Selector 2-4
510 Gear Selector 5-N
288 Gear Selector 6-R
14:42:54 Group 016: Travel Distance
0.1 mm Travel Distance Gear Selector 1-3
-8.4 mm Travel Distance Gear Selector 2-4
0.1 mm Travel Distance Gear Selector 5-N
-8.5 mm Travel Distance Gear Selector 6-R
14:42:56 Group 017: Synchronous travel path
-2.8 mm Synchronous travel path 3rd gear
-3.1 mm Synchronous travel path 2nd gear
0.0 mm Synchronous travel path N gear
-2.4 mm Synchronous travel path R gear
14:42:59 Group 018: Synchronous travel path
3.4 mm Synchronous travel path 1st gear
3.1 mm Synchronous travel path 4th gear
2.5 mm Synchronous travel path 5th gear
2.6 mm Synchronous travel path 6th gear
AFTER:
14:34:56 Group 006
21.5 % Safety valve 1 (N233)
0.804 A Main pressure valve current
14:34:44 Group 010
Kick-Down switch
-2.0 Nm Engine torque
45.0 Nm Engine torque (loss)
14:34:35 Group 013
21.5 % Safety Valve 1
14:34:32 Group 014
22.0 % Safety Valve 2
14:34:30 Group 015: Gear Selector
520 Gear Selector 1-3
283 Gear Selector 2-4
295 Gear Selector 6-R
14:34:27 Group 016: Travel Distance
0.2 mm Travel Distance Gear Selector 1-3
-8.6 mm Travel Distance Gear Selector 2-4
0.0 mm Travel Distance Gear Selector 5-N
14:34:25 Group 017: Synchronous travel path
-2.5 mm Synchronous travel path 3rd gear
0.1 mm Synchronous travel path N gear
-2.6 mm Synchronous travel path R gear
14:34:10 Group 018: Synchronous travel path
3.2 mm Synchronous travel path 1st gear
2.8 mm Synchronous travel path 4th gear
2.4 mm Synchronous travel path 6th gear
Thanks in advance.
