Thread: Fuel gauge not working
  1. Fuel gauge not working
    Oct 2009
    Scotland
    I've read a lot of threads with the same problem of the fuel gauge reading empty but they all seem to end with replaced under warranty, my cars a 2005 3.0TDI Quattro with 80000 miles so not under warranty. Is there a guide to replacing the faulty sender yourself as i'm no longer working. Thanks!
  2. Re: Fuel gauge not working
    Oct 2010
    Berkshire, UK
    Does the DIS state the fuel range? If it does, does it seem accurate?
    If the answer to the abopve 2 is yes, then it is the fuel gauage itself.
    If the answer to the above is no, then it is the sender or another electrical fault.
    YOu can get to the sender after removing the rear set cushions. There is usually an inspection panel that you can remove to get to the sender.
    Either way, a diagnostic will tell you for sure.
  3. Re: Fuel gauge not working
    Aug 2010
    West Sussex
    Hi all,
    Yesterday, I faced this problem too. My fuel gauge is showing empty even though I have about half tank of fuel.
    I was wondering is there anyway I can fix this or do I have to bring it to a garage.
    Sigh...
    Cheers.
  4. Re: Fuel gauge not working
    Do you have a meter that can measure ohms ( Resistance )
    Also tell me exactly which car model you have, some have different tanks and fuel sensor locations. Regards Peter
  1. Please Help b5 tdi fuel gauge not working
    By slats0356 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2010, 07:36 PM
  2. Fuel Gauge
    By H17E5H in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-04-2010, 07:51 PM
  3. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  4. audi a4 fuel gauge doesn't work
    By mark538 in forum Audi A4 - Archive Topics
    Last Post: 14-01-2008, 10:25 AM
  5. Reversing light and fuel gauge - can you help?
    By mr gray in forum Audi A3 - Archive Topics
    Last Post: 12-09-2007, 10:47 AM
