Thread: 'Slipping' Auto gearbox 2.5TDi Allroad?
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2011
    Kent UK
    Quote Originally Posted by kid-jensen View Post
    Seems OK to me, until I read your comment about it "is still in fact in second". How do you know it's still in sccond?
    Apologies, my initial explanation was not very clear. I first noticed the changes in revs when in 'D' and it just didn't feel like a full on change of gear, just a change in revs. So I used the Tip to change manually from 1st to 2nd and keep it in 2nd and watch the revs. Doing this I could see that the revs would rise up to about 2500rpm then dip back a couple of hundred during acceleration, whithout a change into 3rd. A similar thing seems to happen in 3rd also, but to a lesser extent. It may well be a normal function of the gearbox, just not sure really.
  2. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Apr 2009
    Epsom Downs
    I guess it could be the torque converter locking, but I'm not sure if it's supposeed to....
    Someone here must know.
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  3. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Aug 2010
    Wimborne UK
    May be a bit off the wall - have you checked state of battery? I had a flat battery after parking for a week at Heathrow - after a boost the alternator was also knackered so had to get a relay home. The symptoms you describe sound similar to what I was experiencing before this episode, however, since charging the battery up and installing a new alternator, apart from being a lot poorer in the wallet department, my gear changes appear to be a lot smoother in the lower gears than they were. just a thought...
  4. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2011
    Kent UK
    Quote Originally Posted by snooky1 View Post
    Hmmm....interesting. When I bought the car, the previous owner said the battery was less than a year old. When I checked it, it seems too small for the compartment, so may not be up to spec. I think it is a type 096, rated at 72AH. Is this adequate, what rating battery should it be?
  5. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Oct 2010
    Mougins France
    I don't wish to scare you but I suggest the gearbox oil change is done sooner rather than later. I had exactly the same issues with mine (without the clunk between gears but same slipping) and mine just gave up on the motorway cruising. Now I need a replacement box! Very expensive for a car worth only 3.5K.
  6. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2011
    Kent UK
    Quote Originally Posted by Nev.d.y View Post
    Thanks for the heads up. My 2 post lift is being installed on Monday, and I have VAG COM now, so will hopefully get the fluid changed soon.
  1. gearbox transmission fault A4 SE Auto Tiptronic
    By bwfcboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2010, 08:23 AM
  2. Can i swap my auto gearbox and ecu with another model B5?
    By eddy7679 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-09-2009, 03:51 PM
  3. fitting tip auto gearbox
    By gadget4321 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2008, 12:17 PM
  4. T4 question regarding auto gearbox
    By harty in forum The Commercial Range
    Last Post: 06-12-2007, 11:40 PM
  5. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
