Thread: 'Slipping' Auto gearbox 2.5TDi Allroad?
Results 1 to 10 of 16
  1. 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2011
    Kent UK
    3
    Wondering whether anyone can help me with the following? Had the car about a week and have noticed what I would consider a slightly strange gearbox trait.
    A few seconds after a change up up from 1st to 2nd, the revs fall back for a second time, almost like it has changed up another gear but is still in fact in 2nd. Could this be the torque converter clutch slipping?
    Also, sometimes when coasting to a stop or very low speeds, the change down from 2nd to 1st happens with a pretty heavy 'thunk'.
  2. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2010
    Lancashire UK
    1
    Is this in D or manual?
    Charlie
  3. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2011
    Kent UK
    3
    Auto (as per the title )
  4. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2010
    Lancashire UK
    1
    OK, lets try again.
    Is this when the auto transmission selector is in the position D or is it whenit is in the possition to the left where you can (Semi) manually select the gears?
    Charlie
  5. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2011
    Kent UK
    3
    Quote Originally Posted by Sparky Charlie View Post
    OK, lets try again.
    Charlie
    Ah, apologies, I'm with you. The first 'problem' is in either mode. First noticed it in 'D', but tested it in 'M' and the same happens.
    The second issue of thunking going into 1st gear seems worse when in manual mode. Hope that makes sense.....
  6. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2010
    Lancashire UK
    1
    I would start with an oil and filter change. It might be just low on oil.
    There is a special procedure for refilling but it's not that difficult.
    Charlie
  7. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2011
    Kent UK
    3
    Charlie
    Was thinking along those lines, but have read as many people say 'leave the oil well alone' as those who say change it....... Where can I find the procedure for re-filling it? (I have a 2 post lift so hopefully that will make the job a bit easier)
  8. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Feb 2010
    Lancashire UK
    1
    If you are just doing an oil swap. Clean the botttom of the gearbox so no dirt can get in. Drop the oil, remove the pan,swap the filter, clean the magnets in the bottom of the pan, refit pan. With the engine and gearbox cold, pump oil in until it runs out. Start the engine. Run the transmission forward whilst some one replenishes the oil. Run the tranmission in reverse and carry on re filling. Refit the plug and road test. I can't remember the temp the oil has to be below. Seem to think it was 60c. The box holds 9l of liquid gold I only got 7 and a bit back in.
    HTH
    Charlie
  9. Thanks toadus thanked for this post
  10. The Following User Says Thank You to Sparky Charlie For This Useful Post:
    toadus (28-02-2011)
  11. Exclamation Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Sep 2009
    A406
    30
    Gearbox oil change could help.
    What I found is tip always has this "slipping" in first two gears, then from third it fully engages.
    You could try this:
    While in Auto driving in third gear slow down to about 1500, then switch to tip mode, select 2nd gear again let it slow down to about 1500 or less (before it shifts down automatically) and then accelerate sharply.
    Gear box should not slip, could also try this in third gear.
    By the way if it was slipping should it not have stored a fault by now?
    V6 Tdi Power!
  12. Re: 'Slipping' Auto gearbox 2.5TDi Allroad?
    Apr 2009
    Epsom Downs
    1
    Toadus,
    The symptoms you describe in your first post are exactly what I get, and I've never found it to be a problem.
    Presumably, you are talking about acceleration on a light throttle?
    If so, the tiptronic, having decided to change from first to second, has no reason to stay in that gear (because you are not asking for any hard acceleration), so changes onto third. Seems OK to me, until I read your comment about it "is still in fact in second". How do you know it's still in sccond?
    You'll be pleased to know that I also get the clonk when coming to a stop in "manual" mode, but I've learned to live with it...
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  1. gearbox transmission fault A4 SE Auto Tiptronic
    By bwfcboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2010, 08:23 AM
  2. Can i swap my auto gearbox and ecu with another model B5?
    By eddy7679 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-09-2009, 03:51 PM
  3. fitting tip auto gearbox
    By gadget4321 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2008, 12:17 PM
  4. T4 question regarding auto gearbox
    By harty in forum The Commercial Range
    Last Post: 06-12-2007, 11:40 PM
  5. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
