Thread: Rear light cluster removal
Results 1 to 10 of 20
  1. Rear light cluster removal
    Feb 2009
    Glasgow UK
    62
    Hey guys, I know sumthin similar may have been posted before, but can't find what I'm looking for and thought perhaps you might help?
    As some of you may know, may have experienced yourselves, I suffer from the rear light cluster and condensation.....( this is my 6th set approx, all under warranty )
    Lets face it Audi just haven't resolved this problem, period!
    Ok.....so I opened the boot and removed the side panel, then proceeded to remove the plasticnut affair. It has a slot for a plain screwdriver as supplied in the tool kit.
    Then levered off the light from the front piece of the light assy to loosen them from their nipples.......so far all good.
    Now of course they have the plastic piece attached on the inner side of the boot area, but I cannot seem to bufge them without fear of damaging something. They just still seem attached somewhere and I'm loathe to pull harder for fear of breaking the light assy.
    I'd really like to get them removed, dried out and possibly run a line of silicone along the edges to see if that helps solve the problem...can't hurt anyway!
    If anyone knows about this, or there is a wrte up c/w pics, or someone would like to do one, I'd be grateful
    Thanks in advance guys
  2. Re: Rear light cluster removal
    Sep 2009
    Broxburn
    6
    Hi Mate
    This is a bitch of a problem - I went through the exact same issues as taking my light off to replace it. I ended up wasting 3 hours trying to fathom out where the other fixing was hiding. There is no other fixing in there believe it or not even though it feels like there is.
    Take of the plastic fixing as you did. This loosens the light assembly. Now you need nerves and some padding to do the next bit. Get a screwdriver and I used some card. Place the card between the plastic light and the metal of the car body, edge the screwdriver in and leaver it out slowly. The lamp has an appendage that sticks into a receptacle inside the car to secure it so you need to leaver this out. It does come out eventually but you need to be carefull that you dont mark your paint work as it can be so easy to do that.
    I bought a new lamp assembly from ebay fitted it and then had an a..se run into me and crack the new one. If only Id had waited id have saved myself money ! It is easy to do the job but it does make you feel really uneasy doing it ! Best way to describe it is that think on a headphone jack you plug that into a socket and it stays, thats exactly how I would describe how the fixing works. and if its been stuck in there then it will take a little effort to pull the assembly free from the car. Oh and my new assembly has condensation issues aswell.
    2006 Audi 2.7 V6 TDi SE Bose surround soundIColour SatNavIBluetoothIFull leatherIHeated seatsIWalnut trimIRear park assistIInterior ambient lightingICD Changer
    2009 BMW Z4 23Sdrive Colour HDD SatnavIBluetoothIExtended LeatherIBrushed Aluminium TrimIRear Front Park AssistIFolding Roof
  3. Re: Rear light cluster removal
    Feb 2009
    Glasgow UK
    62
    Quote Originally Posted by ruggedscot View Post
    Hi Mate
    Hi Rugged.....please see in bold your reply
    This is the part I tried to explain.....I know about this and did that part, so, assume that those male / female connectors have been loosened AND the plastic threaded nut has also been removed, so far all good?
    The assy still seems stuck connected somehow?
    The only thing I can imagine is that at the side of the lights ( inner side near the water drain channel there are black plastic covers....presumably to try and stop water ingress in some way and they may need to be removed?
    I'll try and post up some pics when I can
    Jim
  4. Re: Rear light cluster removal
    1
    PM me your email address and I'll send you the Audi drawings of how to remove the light fitting. Regards Peter
  5. Thanks JimC64 thanked for this post
  6. The Following User Says Thank You to Peter D For This Useful Post:
    JimC64 (14-02-2011)
  7. Re: Rear light cluster removal
    Sep 2009
    Broxburn
    6
    Jim - let me know how you fare with the drawings - I did this a bit back and do remember struggling with the plastic - these are easily damaged - the instructions should help you.
  8. Re: Rear light cluster removal
    Feb 2009
    Glasgow UK
    62
    Peter D - Many thanks for your kind offer on this forum AGAIN
    You have helped me before Peter, and many many other members as I have seen in lots of different posts across the site.
    Kudos to you for all the great work you do here, much appreciated
    Pm sent
    Ruggedscot - I'll keep you informed and let you know how it goes
  9. Re: Rear light cluster removal
    May 2009
    Newcastle-under-Lyme Staffordshire
    229
    Hi Jim,
    If they are the same fitting as Mrs F's old A3, then each light unit has a small sperical 'nodule' attached to the back of it, up towards the leading edge of the light. This fitment engages into a corresponding hole in the car body, and is quite a tight fit. Once the nut holding the light unit has been removed, it's just a case of wiggling the light backwards and outwards gently, until the fitting pops free, or as ruggedscot suggests, you can try gently levering with something that will not mark the paintwork.
    Good luck!
    MF.
    MY2012 A6 Saloon 2.0TDi S line - Ice Silver, Tech Pack, DAB, Storage Pack, Lighting Pack, Heated F+R Seats, 4 zone A/C, 75l Tank, 20" Rotors, Boot Liner, Umbrella Brackets. VCDS mods: Needle sweep, VIM, Beep on lock, Hidden Menu, Kerb lighting, Mirror Dip on Reverse.
    A6 figure salary, A6 pack, A6. One out of three is a start!
    Got an A6 TDi? Join the A6 TDi Club! Got an A6 Le Mans? Join the A6 Le Mans Club!
  10. Re: Rear light cluster removal
    Feb 2009
    Glasgow UK
    62
    thanks MF....I may not have explained myself propery in previous posts.
    I know about the male / female connector or nipple type arrangement on the car lights which correcpond to the body and have levered the light free from these, thats not the problem!
    On the side of the lights ( inner side which sits in the water drain channel ) there are black plastic covers and its perhaps these that still seem to hold the lights in place somehow?
    Anyways - Peter D has sent me a tech drawing on how to remove the lights which show these and they do have to be removed, so we'll see.
    Thanks anyway for the reply, much appreciated
  11. Re: Rear light cluster removal
    Sep 2009
    Broxburn
    6
    Hope it goes well went well.....
    Gav
  12. #10
    May 2009
    229
    Oh, and don't get tempted into using a sledgehammer. It can only end in tears!
    Snet form my fumblefingers
    iPhon 5 usig Tapatalk
  1. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  2. 4 Motion soft suspension
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 09:25 AM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. How does the Quattro system work?
  5. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
