Thread: Help! Put Unleaded in my Diesel
Results 1 to 10 of 20
  1. Help! Put Unleaded in my Diesel
    Apr 2009
    Epsom Downs
    1
    I've put about 1/4 tankful of unleaded in my Diesel 2.5TDI.
    It was running OK for the journey back from the Petrol Station, now it won't start...
    Any advice?
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  2. Re: Help! Put Unleaded in my Diesel
    1
    1/4 of a tank on top of how much deisel. Not that it really matters as it won't start then you are going to need to drain system change the filter, prime and bleed it, depending on the engine, and fire it back up. Regards Peter
  3. Re: Help! Put Unleaded in my Diesel
    Apr 2009
    Epsom Downs
    1
    Thanks for getting back,
    It's completely full at the moment with aprix 3/4 diesel.
    Is the procedure for draining, priming etc in ELSAWIN?
    Allroad 2.7 TT 2004
  4. Re: Help! Put Unleaded in my Diesel
    Apr 2009
    Epsom Downs
    1
    Had a look at ELSAWIN, it appears you can take of the fuel pipe and jump a fuse in the fuse box to get the pump to run.
    Could I use this to empty the tank?
    If I'm sucessful, would I need a vacuum pump to pull the new (uncontaminated) fuel through?
    Are there vacuum pumps affordable or would it be best to throw it at the dealer?
    Allroad 2.7 TT 2004
  5. Re: Help! Put Unleaded in my Diesel
    1
    You need to supply the engine code. However you have an Allroad so running the pump is to keep the baffle pot filled up by running the jet pump if the tank is less than 1/3 full. Elsa details how to drain a large amount of fuel out but not all. Where are you going to put 70 odd litres of mixed fuel.
    To bleed the system and if all else fails then place a piece of pipe into a large glass or ridgid plastic bottle with the pipe going to the bottom of the bottle then offer up a suitable vacuum cleaner attachments and tape it onto the open neck of the bottle ensureing you do not squash the pipe. Check it is air tight. make sure the container can NOT fall over or the vacuum will injest fuel, connect it all up to the tandem pump and turn the vacuum on and it will pull the fuel through for you filling the bottle. Avoid injesting ANY fuel into the vacuum, it is 25% petrol
    You will need to put quite a lot of fuel in to refill the baffle and get the deisel content up. Regards Peter
  6. Re: Help! Put Unleaded in my Diesel
    Apr 2009
    Epsom Downs
    1
    Thanks,
    Engine number is AKE 132625.
    I can store the contaminated fuel temporarily..
    Looking at ELSAWIN, (attached drawings) it looks like I can follow the manual
    "Detach fuel return line -3- coming from injectors of right-side cylinder bank at injection pump. Fit a suitable length of transparent hose -1- onto the free connection at the injection pump and use an adapter -2- to run the hose into a suitable container (fuel canister or similar). Operate remote control switch until fuel comes out of hose free of bubbles."
    Seems to me that I can attach a hand pump here (I've just found one) and suck all the fuel out into a container.
    Or even easier, jump the fusebox and get the fuel pump to do all the work.
    How does that sound ?
    Allroad 2.7 TT 2004
  7. Re: Help! Put Unleaded in my Diesel
    1
    Correct with your serial number the pump actually drives the jet pump and acts as a lifter so you do not need a vacuum puller. Regards Peter
  8. Re: Help! Put Unleaded in my Diesel
    Mar 2008
    High Wycombe
    71
    Are you with the AA? - they have special "misfuel patrols" which can sort it all out.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  9. Re: Help! Put Unleaded in my Diesel
    Apr 2009
    Epsom Downs
    1
    Looks like I have a fix of sorts..
    Went out this morning to start disconnecting fuel lines and do some serious bleeding......and the bloody thing started !
    Ran a bit rough at first, but it was running.....and I was no longer stranded.
    As the tank was completely full, I used my hand pump and a piece of PVC hose about the length of the channel tunnel (where does it all go?) to suck out as much as I had containers for..
    With the engine still running, I managed to get the level down to just above 1/4 full before I ran out of cans...
    Off to the petrol station and filled to the brim with new diesel. I recon there is about 1/8th petrol in there at ther moment and I'll keep topping up to gradually reduce it. I'll also try leaving the filler cap off so the petrol gradually evaporates.
    Car starts and runs just fine now, but I'm taking it easy until I can be sure the petrol percentage is insignificant.
    Assuming nothing blows up, it could be that I've "got away with it" (for now).
    I'm sure some sort of damage has been done in one way or another, but time will tell what it is.
    Next job: Change the filter.
    Then I'll get to try out my bleeding technique....
    And talking of bleeding, I still haven't got round to doing the brakes!
    Allroad 2.7 TT 2004
  10. Re: Help! Put Unleaded in my Diesel
    May 2010
    Devon England
    273
    sounds like you have been lucky, it might pay to put a fuel treatment in the tank, something like Forte diesel treatment, just to be on the safe side mate
    OWN A MK5 GOLF TDI JOIN THE GROUP http://www.vwaudiforum.co.uk/forum/group.php?groupid=23
  1. Question Sharan 03 1.9 diesel notchy gear change 1st to 2nd
    By rbraddley in forum Touran - Sharan - Caravelle
    Last Post: 25-01-2011, 11:52 AM
  2. Question Wrong fuel in Diesel
    By deepee in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-01-2011, 01:37 PM
  3. Diesel Particle Filter
    By prolfe in forum Chat - Anything with wheels - Sponsored by LVS Racing Ltd
    Last Post: 08-10-2009, 07:08 PM
  4. Question Shell V - Power Diesel
    By Zeb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2009, 10:55 PM
  5. Biodiesel - a summary
    By Huweth in forum Chat - Completely Off Topic - Sponsored by Shiply
    Last Post: 06-01-2009, 06:25 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
