Thread: Fuel temp. sensor error 16565
Results 1 to 8 of 8
  1. Question Fuel temp. sensor error 16565
    Dec 2010
    central england
    Golf MK5 1.9tdi 55 plate
    Came up "Emissions Workshop" Vcds Code 16565 Fuel Temp Sensor. VW part no.?
    Where is it located & can it be cleaned or best replaced?
  2. Re: Fuel temp. sensor error 16565
    May 2010
    Devon England
    it is located on the fuel line between the filter and tandum pump, at the end of the cylinder head, they cant be cleaned tbh best thing is to replace it
  3. Question Re: Fuel temp. sensor error 16565
    Dec 2010
    central england
    Thanks for that.
    Remove and checked Resistance as follows:-
    Room Temp...........4.9 k ohms
    Cold water............6.5 k "
    Warmed by hand...3.5 k "
    Are the above meter readings OK??
  4. Re: Fuel temp. sensor error 16565
    1840 Post(s)
    A common failure.
  5. Re: Fuel temp. sensor error 16565
    Dec 2010
    central england
    I had fitted a "Tuning Chip" that plugs into the FTS.
    I have seen elsewhere that this Chip can give spurious errors, so looks like this could be the problem.
  6. Re: Fuel temp. sensor error 16565
    1840 Post(s)
    Yes they do!
  7. Re: Fuel temp. sensor error 16565
    Oct 2014
    United Kingdom
    A common failure.
    what are the symptoms of a failing fuel temp sensor..... Got rough hunting idle when cold but drives perfect though ....when engine up to temp idle is ok
  8. Re: Fuel temp. sensor error 16565
    1840 Post(s)
    Engine MIL on and a fault code saying the sensor is faulty or open circuit.
  1. Question Coolant temp in matrix drops when i accelerate
    By irishpassats in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 04:22 PM
  2. Fuel Supply Prob. after new filter
    By richard@thebrae in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2008, 04:32 PM
  3. A3 fuel and temp gauges
    By walanis in forum Audi A3 - Archive Topics
    Last Post: 09-02-2007, 09:12 AM
  4. ADVICE RE Removing Fuel Temp Sender
    By JR001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-12-2006, 01:04 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
