Thread: A4 1.9tdi 130 - ESP light and flashing glow plug light
Results 1 to 10 of 10
  1. A4 1.9tdi 130 - ESP light and flashing glow plug light
    Jan 2011
    Hull
    Hi just joined up and was looking for any ideas. I have owned my 2002 A4 1.9tdi 130 sport for 5 1/2 years now and its just hit 130k miles.
    About 2 weeks ago the ESP light came on and the car went to limp mode, after 5 mins the glow plug light started flashing. When I turned the car off and on again, all seemed well. Next day the ESP light came on again and after restarting it was OK and has been since.
    It now seems to be 'bogging' down when setting off and between gears, it also occasionaly if you lift off the throttle (in third) an put your foot down again it seems to missfire.
    Has anyone had the same problem?
    Sorry for the essay but wanted to cover everything!!
  2. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    Southern County Softy
    20 Post(s)
    get the car scanned for faults.
    Check your brake lights
    A4 2.5 tdi QS (mapped)
  3. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    Jan 2011
    Hull
    Thanks Kite, brake lights are working, have lost a headlight bulb tho'
    put it on a cheap ODB2 hand held scanner last night which plugged in near the bonnet release and it said no faults. Will a garage scanner pick up faults this hasn't? Do the cars store previous faults?
  4. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    20 Post(s)
    the brake light switch is a double switch, it sends info to the ECU and the brake lightsa.
    If you look in the vagcom section you may find a member in your area to scan the car with VCDS.
  5. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    Jan 2011
    Hull
    Thanks again Kite.
  6. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    Dec 2009
    southampton uk
    May not be this but I had the missfire and ESP light on with my 2.5TDI recently .No faults showed on VAGCOM except poss brocken wire and someone said the injector loom may have a bad connection so I did my best to check and tighten the connectors and so far after 3 weeks no recurrence.
  7. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    Jan 2011
    Hull
    Thanks, the car is in the garage tomorrow to have the fault codes checked. I'll let you know the result!!
  8. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    Jan 2011
    Hull
    Got the car checked today and the only fault code was for an engine mount solenoid Why do the engine mounts have solenoid valves?
    Also, my drivers side headlight dipped beam bulb has blown, how do I get to change it please?
  9. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    20 Post(s)
    a nice lttle how to change bulbs....
    https://www.vwaudiforum.co.uk/forum/s...ead.php?t=7485
  10. Re: A4 1.9tdi 130 - ESP light and flashing glow plug light
    Sep 2008
    chester
    17 Post(s)
    The engine mounts are active i.e. they stiffen and soften dependant on engine load,dont think its the cause of your esp light though,do a search of posts for brake pedal switch.
  1. Question a4 tdi in limp mode and glow plug light flashing
    By iwa.r8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:33 AM
  2. How To ABS + ESP + glow plug light flashing
    By Camb-Tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2010, 05:56 PM
  3. ESP & Glow Plug light flashing & no power
    By A4philb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-05-2009, 03:42 PM
  4. A4 TDi - glow plug light flashing, will not rev up past idle speed
    By tom fenton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 07:49 PM
  5. Flashing glow plug light on 03 Ibiza 130 TDI sport
    By Maitland_78 in forum Ibiza - Cordoba
    Last Post: 10-04-2008, 04:45 PM
