Thread: Audi A4 problems
  1. Audi A4 problems
    Doug Guest
    I own a 1997 Audi A4, with a 1.8L non-turbo engine.
    I need new spark plugs, but here's the problem:
    I purchased the car in Europe, drove it a few years there,
    and then brought it to the US where I am now.
    Unfortunately, the A4 non-turbo version has never been sold in
    the US, and Audi-USA is completely clueless about replacement
    parts.
    Presumably the spark plugs and spark plug wires are not the
    same as for the 1.8L turbo version (which is sold in the US)...
    Is there any way to find out what replacement parts might be
    both compatible and available in the US? I'm not averse to
    ordering from the UK if need be..
    Many thanks in advance,
    Doug
    Oct 2005
    Lutterworth
    According to sparkplugs.co.uk you can use the same plugs as a 1.8T AEB engine in your ADR.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Jul 2007
    hi,i have a audi a4 1.9 tdi 110 bhp on a 97 plate.the glowplug light has been flashing at me for a couple of weeks now and now the car wont start at all.ive removed the glowplugs and cleaned them all up and ive serviced it.the car will run for about 2 seconds but dies straight away after.im at my wits end with this car ive had it 8 months and its the biggest p.o.s ive ever had it spends more time off the road than on!!!!!!!!!!!!!!
    Jan 2006
    Southampton
    I'll think your find the light flashing means there could be a problem with the engine management not just the glow plugs your need to take it to somebody with vagcom or similar diagnostics
    Phaeton 3.0 LWB
    Lotus Carlton
    If you have to ask you wouldn't understand
    May 2007
    Rochdale
    Flashing glow plug light can indicate a fault with the brake lights. Check the bulbs and the switch. As far as not running check the fuel cut off swtch or the fuel pump or the fuel filter
    Hope this helps
    Jul 2007
    Hi All
    I have an 1996 AUdi A4 1.6SE, can anyone tell me where i can get a sump spanner, i havent had a good look yet but i have an obvious oil leak and first thing i was going to check was the sump
    Thanks in advance.
    Supahoops
  1. New Audi A6 Avant 2.0 T , having problems
    By sauce71 in forum New Member Introductions
    Last Post: 13-06-2007, 01:05 AM
  2. Audi A4 Heater problems
    By Pete K in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2007, 12:49 PM
  3. Audi A6 2.6 V6 Idle Problems
    By WADZ000 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-02-2007, 07:42 PM
  4. Audi A4 DIS Computer Problems
    By baboon in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-01-2007, 09:26 AM
  5. Audi 80 2.e Auto box problems
    By davro in forum 80 - 90
    Last Post: 23-02-2006, 08:50 PM
