Thread: A6 Parking Brake Stuck ....
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Smile Re: A6 Parking Brake Stuck ....
    Aug 2012
    United kingdom of great britain
    thanks will take a look over wknd
    Quote Originally Posted by apole View Post
    One thought, if it is a damaged cable, can youget underneath and take a look at both and try to confirm? It you see damage, either repair yourself as best you can, get new cable fitted, or get an auto electrician to make good.
    If it's not the cable, then I guess you have to leave it to Audi or a specialist.
    Can anyone with experience of this issue recall where the damage occurs to make finding it easier?
    Also found this TSB which may not be relevant if the cable is damaged !!
    http://uberlame.com/a6_tsb/Brakes/El...%20release.pdf
  2. Re: A6 Parking Brake Stuck ....
    Aug 2012
    Eindhoven, Netherlands
    I had same problem last year (Audi A6 3.0TDI quattro, 2005 model) and found out parking brake cable was broken at connector near the wheel. Root cause is that this is a design flaw from Audi; cable is actually a bit (too) short. When changing winter and summer tyres (wheels in my case), the wheel comes out of its suspension maximally, thus stretching the wire to the max. This results over time in cable breaking internally (so insulation still ok, but feels weak when moving).
    I fixed it by:
    1. unplugged the connector (first unlock the connector mechanically by shifting a part!) and cut it from the cable, to take it to my workbench. Note the wiring colours to ensure you connect it rightly later!!!
    2. then took out the metal connector pins (pay attention to push the little barb preventing it from coming out normally),
    3. soldered an extra piece of (thick enough, high currents!) wire to the connector pins
    4. assembled the connector again and took that back to my car
    5. soldered the wire to the original cable and plugged it in again.
    Note: if you ask you Audi garage to fix it, then they will replace the complete cable assembly which runs right to the front of the car, i.e. cost you a few 100s of Euros at least!
    Last week I appeared to have the same problem, but that was different. Indeed it was due to hot brakes when switching on the car after a coffee brake during a long drive in the French heat, see http://uberlame.com/a6_tsb/Brakes/El...%20release.pdf, 'Customer's manner of use' (thanks for the hint, apole!!). That was easy to fix :-).
  3. Re: A6 Parking Brake Stuck ....
    Colchester,Essex
    All I fixed so far on b6 passats normally calliper or the switch.Good to know a 6suffer with wiring.
  1. Question Electro-magnetic parking brake at high speed
    By tester in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-01-2011, 01:51 AM
  2. Dodgy NSR Parking brake - 54 plate A6 Manual
    By pimpin gimp in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-08-2010, 10:09 PM
  3. Parking Brake no longer releases automatically?
    By sunil1234 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-04-2010, 09:18 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
