Thread: A6 Parking Brake Stuck ....
Results 1 to 10 of 13
  1. A6 Parking Brake Stuck ....
    Aug 2009
    London
    2
    Hi there,
    Car is Audi A6 - 2.0 SE TDI - 2005 model
    Was wondering if anybody is familiar with faulty electronic parking brakes. Had a warning light come on today and it wouldn't apply correctly - then light went off and it functioned correctly. Just gone out to drive and the damn light came back on and it refuses to disengage the brake, so i'm effectively stuck.....
    Would welcome any advice on this most readily.
    Thx.
  2. Re: A6 Parking Brake Stuck ....
    Apr 2010
    Edinburgh, Scotland
    0
    Quote Originally Posted by jon3boy View Post
    Hi there,
    Thx.
    Had the same problem with mine a couple of years ago, turned out to be a frayed/damaged/severed cable to one of the wheels which froze the handbrake on. There are two options for a fix, RAC came out and spliced cable with connectors to get me going again or you'll need to get the whole cable replaced. If memory serves this was a known problem for early C6 cars with later cars having a more robust cable fitted.
  3. Re: A6 Parking Brake Stuck ....
    Aug 2009
    London
    2
    Thx for reply ceegee - I managed to get the brake disengaged by luck over judgement: constant messing with the switch and throttle seemed to dupe it into a false sense of security....
    I've taped over the switch so i can't inadvertantly apply the brake without warning and obviously leave it in gear when parking it - although i have found that there is a lot of learned behaviour with regards to pressing the clutch pedal b4 ignition.... nearly rolled into parked stuff on 2 occasions. Car is going to be diagnostically evaluated at Tonbridge Audi on Tuesday and i will post the results hereafter in an attempt to broaden the knowledge of faulty parking brakes.
  4. Re: A6 Parking Brake Stuck ....
    Aug 2009
    London
    2
    An hour's diagnostic served only to show that faults were found with F234 switch and J540 Control unit.
    The guys said that i'd need to rebook it in for 1-2 hrs so they can get at what they need to thro the boot.
    Now if this is just a loose wire or faulty switch - i can see the hrly diagnosis charges - which are @ 140 an hr - + the switch coming to god-knows how much - just for a dumb electronic malfunction...
    Just wondered if anyone could advise a different method of resolution with potentially less damaging financial implications...
    Thx
  5. Re: A6 Parking Brake Stuck ....
    Aug 2008
    0
    Just to add that i had the same problem last year, parking brake would not disengage. Ended up being a damaged cable, mechanic ordered the part from audi and spliced it in. All in it cost me about 150 quid.
  6. Re: A6 Parking Brake Stuck ....
    0
    I had the same problem. Did you know that if it's stuck on, put your seatbelt on and put the car in 1st gear, then slowly pull away and it will automatically disengage the brake. RAC guy told me this over the phone when he was on his way to see me. Works fine which means I don't have a reliable handbrake but atleast I won't get stuck!
  7. Re: A6 Parking Brake Stuck ....
    Nov 2010
    Buckley
    0
    hi, i have had the same problem with the driver side rear parking cable damaged, it looks like the cable was replaced and spliced in by the last owner, it has been removed by rac from the connector by the wheel and i have been using the epb and its working only on the passenger side. i am hoping someone can tell me what the part no or what the part is called and if i can order it from an online retailer rather than audi, i have someone that could fit it for me.
    thank you
  8. Re: A6 Parking Brake Stuck ....
    Dec 2006
    0
    Same thing has happened to me - I have been driving around with it taped up for the last few months and have got quite used to driving without a handbrake. However, i have it booked in to an Audi specialist in Basingstoke on Monday for them to put a diagnostic on it.....
  9. Re: A6 Parking Brake Stuck ....
    Aug 2012
    United kingdom of great britain
    0
    hi,
    recently had my parking brake stick on and car will not start,dash lit up and beeps popping off every where, called AA, he sits in seat and blow me she starts, 2 hrs waiting and re- setting still would not start then ESP came on as being faulty. i love this car and am at a loss can some one advise please.
    brian
  10. Re: A6 Parking Brake Stuck ....
    Jun 2006
    9
    One thought, if it is a damaged cable, can youget underneath and take a look at both and try to confirm? It you see damage, either repair yourself as best you can, get new cable fitted, or get an auto electrician to make good.
    If it's not the cable, then I guess you have to leave it to Audi or a specialist.
    Can anyone with experience of this issue recall where the damage occurs to make finding it easier?
    Also found this TSB which may not be relevant if the cable is damaged !!
    http://uberlame.com/a6_tsb/Brakes/El...%20release.pdf
  11. Likes Fred_A6 liked this post
  1. Question Electro-magnetic parking brake at high speed
    By tester in forum Audi A4 - B8 Forum - 2008 -
    Last Post: 25-01-2011, 01:51 AM
  2. Dodgy NSR Parking brake - 54 plate A6 Manual
    By pimpin gimp in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-08-2010, 10:09 PM
  3. Parking Brake no longer releases automatically?
    By sunil1234 in forum Audi A4 - B8 Forum - 2008 -
    Last Post: 23-04-2010, 09:18 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,Porsche or Lamborghini group of Companies. For official up to date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, Porsche and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
