Thread: A3 Emissions control system warning light
  1. A3 Emissions control system warning light
    Jan 2008
    I have an A3 1.6 MPI 2006MY, which appears to have an intermittent fault with the upstream Oxygen sensor.
    A diagnostic scan reports the following:-
    "Linear oxygen sensor B1 S1 pump current trim circuit open P2626"
    "Sporadic 008 implausable signal"
    When I clear the fault code the Emission warning light goes off, but I noticed that the fault code returns but no warning light comes back on.
    I assume I need a new sensor, but as these are expensive-around £150, and it is a pig to access, and is very tight, are the emissions affected,as its MOT is due shortly?
    The car drives perfectly, and fuel consumption is excellent.
  2. Re: A3 Emissions control system warning light
    1841 Post(s)
    If you don’t replace the sensor the cat could be damaged.
  3. Re: A3 Emissions control system warning light
    Jan 2008
    The car has just passed the MOT. It is unlkely the fault will affect the CAT, although I intend to replace the suspect sensor anyway.
  1. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  2. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  3. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
