Thread: Urgent advice needed - fuel filler flap stuck?
Results 1 to 8 of 8
  1. Urgent advice needed - fuel filler flap stuck?
    Feb 2009
    Glasgow UK
    62
    You guys may recall I posted into the battery drain thread, where my car has failed to start, had 2-3 new batteries etc etc.
    It has been at the dealership for around 4 days while they've had it hooked up checking to what drain there may or may not be.
    During this process they've shut off this n that etc etc but surely the fuel filler cap can't be part of this routine??
    I have it back ( inconclusive results and basically no further forward! ) but the problem I have is this.....
    I'm low on fuel and need to fill her up....the fuel filler flap seems stuck in some way ( I've never experienced this before?? ).....I don't think they would have done anything with this during their procedure, but it seems locked fast and will not budge.
    I can't imagine its frozen as its not that cold, currently around -1 and has opened no problems in temps down to -18 or so!!!
    Seems strange to me Any of you ever experienced this before and can you give any advice on how to open it ( preferably without damaging it) ???
    Any advice you can offer, greatly appreciated.
    Many thanks in advance
  2. Re: Urgent advice needed - fuel filler flap stuck?
    Oct 2005
    736
    Can you hear the solenoid trying to pop the filler door?
    On the Passat you can pull back the boot lining and tug the solenoid from the inside.
    Could be a build up of freezing/thawing/freezing etc
    Model Specific Sections: VW || Audi || SEAT || Škoda || Prestige
    ### VWAF Needs You! Please leave your feedback here ###
  3. Re: Urgent advice needed - fuel filler flap stuck?
    Feb 2009
    Glasgow UK
    62
    Thanks mycarsav for the reply.
    Not sure what you mean by solenoid exactly?
    My fuel filler cap is as simple as pushing one end of it inwards and it then essentially springs open!
    BUT.....It doesn't want to seem to play ball
  4. Re: Urgent advice needed - fuel filler flap stuck?
    Oct 2005
    736
    Ah, sorry, I assumed as you had an all singing/dancing A6 there'd be a remote release.
    My lowly ageing Passat has a button on the drivers door.
    Sounds like you have a push-to-release cap, does a screwdriver fit in the gap so you can prise it open? Wrap it in a cloth first to prevent scratching
  5. Re: Urgent advice needed - fuel filler flap stuck?
    931
    No A6s have a remote release However Jim, as mycarsavw says, theres a manual relase in the boot behind the removeable trim where the jack stays I think its a tug/cord thing but not totally sure.
  6. Thanks JimC64 thanked for this post
  7. The Following User Says Thank You to Chris For This Useful Post:
    JimC64 (14-12-2010)
  8. Re: Urgent advice needed - fuel filler flap stuck?
    0
    Behind removable trim where the jack you will see green tug/cord.
  9. Thanks JimC64 thanked for this post
  10. The Following User Says Thank You to bakili For This Useful Post:
    JimC64 (14-12-2010)
  11. Re: Urgent advice needed - fuel filler flap stuck?
    May 2009
    Newcastle-under-Lyme Staffordshire
    229
    Quote Originally Posted by JimC64 View Post
    Yep - there is a metal peg which engages into a hole on the back of the filler flap when the car is locked (to prevent anyone from trying to syphon fuel out). Sounds like this is not disengaging when you unlock the car. As stated above, there should be a green cord behind the boot trim on the right hand side to manually disengage the peg.
    I'd get your dealer to take a look when you get chance - sounds like either the solenoid actuating the peg has failed/seized or become disconnected. Given the proximity of it to the battery in the boot, something may have been disturbed when they were checking out your battery drain problem?
    Good luck!!
    MF.
    MY2012 A6 Saloon 2.0TDi S line - Ice Silver, Tech Pack, DAB, Storage Pack, Lighting Pack, Heated F+R Seats, 4 zone A/C, 75l Tank, 20" Rotors, Boot Liner, Umbrella Brackets. VCDS mods: Needle sweep, VIM, Beep on lock, Hidden Menu, Kerb lighting, Mirror Dip on Reverse.
    A6 figure salary, A6 pack, A6. One out of three is a start!
    Got an A6 TDi? Join the A6 TDi Club! Got an A6 Le Mans? Join the A6 Le Mans Club!
  12. Thanks JimC64 thanked for this post
  13. The Following User Says Thank You to MFGF For This Useful Post:
    JimC64 (14-12-2010)
  14. Re: Urgent advice needed - fuel filler flap stuck?
    Feb 2009
    Glasgow UK
    62
    thanks to you all who replied and gave sound advice. I just checked and there is a RED ripcord ( I was a bit hesitant to pull at first as it looked attached to something else entirely ) however, a gentle tug and the fuel flap opened up fully
    It looks like for some reason the locking pin does not now retract fully
    Anyhow, a quick call to the dealer and I'll be popping in again tomorrow to pick up some parts I've ordered and they'll look at it then and hopefully fix it quickly.
    Thanks again guys
  1. Please Help How to manually open fuel filler flap
    By SteveySteve in forum Golf MK5 - 2004 - 2009
    Last Post: 19-04-2012, 11:57 PM
  2. A6 1.8T Overfuelling
    By soulsearcher in forum VCDS - General Questions
    Last Post: 17-07-2009, 12:53 AM
  3. Fuel Supply Prob. after new filter
    By richard@thebrae in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-04-2008, 04:32 PM
  4. Urgent Help Needed !!! Driver Window Stuck Open
    By danielintheuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-03-2008, 06:17 PM
  5. Diesel fuel starvation (urgent please !)
    By ronmcintosh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-09-2007, 03:54 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
