Thread: Beetle 1.6SR rough idle and power loss
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. Re: Beetle 1.6SR rough idle and power loss
    #21
    Jun 2008
    Thanks Crasher! I've had a breakthrough!!
    I carried out the alignment check as you suggested using the procedure from the Ross-tech site. At first this failed bUt I think this was due to temperature - only 3degs - procedure states it has to be between 5-95
    Anyway I retried after taking the car for a run and it worked. I also did the EGR adaption at the same time.
    This transformed the car, steady tick over and no hesitation when pulling away! - YES!!
    Unfortunately it didn't take too long though before the warning lamp came back on again for the AMM - DAMN!!
    Had a more detailed look today around the AMM and found the air inlet pipe has split where it joins a breather on the rocker cover, so this must be letting unmetered air into the engine!!
    So I'm hoping this along with the throttle body alignment is the culprit. Will order a new one Monday and see if it cures the problem.
    Fingers crossed;-)
  2. Re: Beetle 1.6SR rough idle and power loss
    #22
    Sep 2019
    Stratford upon avon
    2003 1.6sr beetle hunting problem
    I have a 2003 1.6sr beetle that idles rough and revs up and down.
    I've changed the throttle body and have recalibrated it. I've changed the maf and pre cat o2 sensor which all flagged up faults but still the problem is there.
    I've checked for vacuum leaks and cant find any.
    I've even changed the egr valve just incase but still the same.
    No faults codes are showing either on vag com.
    Am I missing anything as its driving me insane.
    Allan
  3. Re: Beetle 1.6SR rough idle and power loss
    #23
    108 Post(s)
    1816 Post(s)
    Not an AKL then, an AYD or possibly a BFS.
  4. Re: Beetle 1.6SR rough idle and power loss
    #24
    Sep 2019
    Stratford upon avon
    Thanks for the reply.
    Will have to plug back in as cant remember but think it's a BFS
  5. Re: Beetle 1.6SR rough idle and power loss
    #25
    Sep 2019
    Stratford upon avon
    Can conform it's a BFS engine
  6. Re: Beetle 1.6SR rough idle and power loss
    #26
    108 Post(s)
    1816 Post(s)
    Did you erase the learnt values in Adaptation 10 before adapting the throttle body in Basic Settings 060?
  7. Re: Beetle 1.6SR rough idle and power loss
    #27
    Sep 2019
    Stratford upon avon
    I didn't no. How is that done?
    Also I have a code come up today which is 01314 engine control module, check DTC memory
  8. Re: Beetle 1.6SR rough idle and power loss
    #28
    Sep 2019
    Stratford upon avon
    Hi crasher, I googled how to do it and I did it but still the same.
  9. Re: Beetle 1.6SR rough idle and power loss
    #29
    108 Post(s)
    1816 Post(s)
    Can you post a full car scan using the # function above
  10. Re: Beetle 1.6SR rough idle and power loss
    #30
    Sep 2019
    Stratford upon avon
    Controller, 1c0 907 379m
    Component, ESP front mk60 0102
    Coding, 0011266
    Shop #. WSC 00066
    1 fault found.
    01314 - engine control module
    013 - check DTC memory - intermittent
    Hi crasher, didn't know how to do what you said so just wrote down the fault as it show on vac com. Hope this helps.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Random Power Loss
    By jonathanfenton in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-02-2010, 08:58 AM
  3. Power loss problem SOLVED !!! A must read
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-05-2008, 02:26 PM
  4. erratic idle and loss of power
    By anya in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-02-2007, 10:16 PM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
