Welcome to the VW AUDI Forum - VWAF.
  1. #1
    Sep 2008
    6
    Handbrake adjustment
    Hello folks
    Is the handbrake adjustment automatic on my 1997 A4 Diesel ?, checked round the lever but cant see anything to adjust
  2. #2
    Sep 2008
    7
    Re: Handbrake adjustment
    Yes, it's automatic. However if it's not engaging properly, it could be the handbrake cable wire has corroded in the sleeve, or the calipers themselves are seized. It's not uncommon for the rear calipers to lock up. Pop the wheels off and get someone to operate the handbrake while you take a closer look.
    If they're seized, then you'll need to rebuild them. Lockheed red grease under the dust-sleeve works well. Fit a new rubber 'o' ring too in the caliper bore. You'll need a universal brake wind-back tool to screw the caliper bore back into the housing. I bought a Draper tool and simply hacksawed off two of the pins so it seated properly. The brakes will need to be bled afterwards to remove any air in the system. Double-check the brake slide pins are not corroded, the dust sleeve isn't torn and they're properly lubricated. I use a little red grease for this job. Finally, give the spring mechanism on the caliper a liberal spray with Duck-oil penetrating release.
    There is a nut on the handbrake yolk that you can manually adjust. Once everything's back together, apply the handbrake several times to manually adjust the rear brakes. With one click on the handbrake, the pads should make contact with the discs. Adjust the nut on the handbrake yolk if necessary.
    In the off position, there should be no contact with the discs. You can test by driving the car for a few miles and coast to a stop. Now touch the discs. If they're warm, the caliper is possibly still sticking or you've overtightened the handbrake cable.
    More details here regards the pads, adjusting caliper piston and brake bleed procedure. http://www.audiworld.com/tech/wheel139.shtml
    2003 A2 1.4 TDi SE (109k)
    2001 (B5) A4 2.5 TDi Avant Quattro Sport (143k)
    1995 (B4) 80 1.9 TDi Avant SE 175k (sold)
  3. Thanks ytre thanked for this post
  4. The Following User Says Thank You to spartacus 68 For This Useful Post:
    ytre (14-11-2010)
  1. Handbrake adjustment after pad change
    By ianhayter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-11-2011, 08:52 AM
  2. Please Help Handbrake adjustment.
    By burnleywhite in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2010, 04:09 PM
  3. Handbrake adjustment
    By usegoldie in forum Alhambra
    Last Post: 26-10-2009, 01:16 PM
  4. How To Handbrake adjustment
    By Andante in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-07-2009, 12:25 AM
Back to top
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
Copyright: VW Audi Forum is an AUTHORISED DEALER for the Surf City Garage range of car care products. All Surf City Garage images are "Copyright" of Surf City Garage
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
- www.vwaudiforum.co.uk - www.vwaf.co.uk - www.vwaf.co.uk - www.vwaudiforum.co.uk -
/p
