Thread: fault code 05658 canbus
  1. fault code 05658 canbus
    Apr 2010
    larne
    any ideas
  2. Re: fault code 05658 canbus
    May 2008
    Quote Originally Posted by peter bacon View Post
    any ideas
    Worst post ever? How about a few details, my crystal ball isn't so good these days.....
    What car/year/engine/fuel etc etc? What symptoms does the car have? Any warning lights on?
    What equipment obtained the code? Was it VAGCOM? Do you have the full scan printout? Did you clear the fault and does it return?
    Glowplugs working OK? (if its even a diesel you have)
  3. Re: fault code 05658 canbus
    1840 Post(s)
    I don’t think it is even a VAG fault code! Certainly not a P code, doesn’t look like a HEX either so probably a machine specific code.
  4. Re: fault code 05658 canbus
    Apr 2010
    larne
    sorry for lack of info its 07 golf tdi 105 brake was tested with a sealey vag reader was cleared and still came back with this code 05658 canbus
  5. Re: fault code 05658 canbus
    1840 Post(s)
    Sorry but I am none the wiser, I cannot find 05658 in any Golf 5 controller. What system was the fault code found in, engine, brakes, central electrics etc? What is the problem with the car?
  6. Re: fault code 05658 canbus
    Apr 2010
    larne
    just bought the car didnt think i had any probs a friend put the code reader on it the code came up on the engine section so was just wondering what it would be
  7. Re: fault code 05658 canbus
    May 2008
    So as per earlier questions that went unanswered... Do you have any warning lights on? Or any running problems/issues with the car?
    If you have no lights on or running probs then I'd forget about it, or get the car scanned with VAGCOM/VCDS instead and go from there because as Crasher says 05658 doesnt come up as a vaild code
  1. Decoding error codes Help!!
    By charbel89 in forum VCDS - General Questions
    Last Post: 17-09-2010, 09:40 AM
  2. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  3. A4 wont start + VCDS showing nothing
    By martybutler in forum VCDS - Help Requests
    Last Post: 11-06-2010, 06:42 PM
  4. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  5. gearbox isolator switch??????
    By a25c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 11:29 PM
