Thread: PRNDS Flashing
  1. PRNDS Flashing
    Dec 2008
    Hi Guys,
    I have a 2004 54 Audi A4 1.8T Multi-tronic Cabriolet and the PRNDS on the dash has just recently started to flash.
    I first noticed this after I accidently drove over a rather large pothole. When the PRNDS is flashing the car appears to be stuck in gear and is a little jumpy when driving off from a static position, otherwise it drives normally.
    This also only appears to happen when the car is warm i.e after it has been constantly driven for 30 mins or so, if I am doing a shorter journey the car does not display any symptons and drives as good as new.
    A further side issue is that the car is drinking more coolant than normal when it is experiencing the flashing problems.
    I have had the car checked by an independant garage and the VAG report is as follows: -
    CODE001: 17137 P0753 Shift Solenoid A-N88: electrical - Output dose not have a contact short to earth
    CODE002: 17134 P0750 Shift Solenoid A-N88: malfunction - Value of resistance too great.
    Can anybody please tell me what this means?
    The garage has suggested that a software update (£60+VAT) may solve the problem, does anybody agree with this conclusion?
    Gordon
  2. Re: PRNDS Flashing
    Aug 2010
    London N10, UK
    Quote Originally Posted by GJC View Post
    Hi Guys,
    Gordon
    there a lots of posts about PRNDS flashing on here - try a little search
  3. Re: PRNDS Flashing
    Dec 2008
    Christopher,
    Thanks for your advice however I have already carriedout a search but most of other posts appear to be relating to different problems from mine. I have included the VAG codes in hope that somebody could advise me?
    Gordon
  4. Re: PRNDS Flashing
    May 2010
    Devon England
    has your drivers side footwell got wet at any point?
  5. Re: PRNDS Flashing
    Dec 2008
    Phil,
    No the footwell is dry, why what were you thinking?
    Gordon
  6. Re: PRNDS Flashing
    May 2010
    Devon England
    Phil,
    Gordon
    well the gearbox control modual is under the drivers front carpet iirc, and we had one at work that was flushing and after getting to the box found it was full of water, couldnt fix it so fitted a new one had it coded and it cured the problem
  7. Re: PRNDS Flashing
    Dec 2008
    Phil,
    Thanks, I'll double check but I'm pretty certain it's dry.
    Any other ideas?
    Gordon
  1. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  2. Touran Automatic - Selector Lights flashing (new member)
    By RoyS in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2009, 03:45 PM
  3. Help - Flashing Wing Indicators
    By sueprend in forum Golf MK4 - 1999 - 2004
    Last Post: 05-03-2008, 10:38 PM
  4. Help Golf Mk 5 flashing wing indicators
    By sueprend in forum Golf MK5 - 2004 - 2009
    Last Post: 04-03-2008, 09:02 PM
  5. PRNDS light flashing
    By garysoul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-01-2008, 12:25 PM
