Thread: Intake Manifold Flap Fault Codes and Cleaning
Results 1 to 10 of 12
  1. Intake Manifold Flap Fault Codes and Cleaning
    Aug 2010
    Hartlepool
    0
    Hi have had the engine management light come on recently (55 plate Golf TDI 140) and after reading / VAG com scan it appears to be the intake manifold flap seized open:
    19557 - motor for IMF (v157): open or shorted to gnd
    p3101
    19558 - motor for IMF (v157): No signal
    p3102
    My plan was to take it off and give it a clean next week. Does anyone know the exact tools I would need, as my toolbox is limited now I have moved away from my dads place? Heard its only allen keys, but uclear what size.
    Carb cleaner sounds like the reccomended fluid to use, can anyone cofirm this?
    2006 Golf 2.0L GT TDI
  2. Re: Intake Manifold Flap Fault Codes and Cleaning
    197
    5-mm allen key. I think you will find it a waste of time cleaning it, I know other people have succeeded but it has never worked for me. Dont forget to replace the blown fuse.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
    www.helpforheroes.org.uk
    Keep XH558 in the air
    www.vulcantothesky.org
  3. Re: Intake Manifold Flap Fault Codes and Cleaning
    Aug 2010
    Hartlepool
    0
    Thanks, might clean the EGR valve and manifold while i'm there.
    Will let you know if I have any luck mate ta, fingers crossed!
  4. Re: Intake Manifold Flap Fault Codes and Cleaning
    May 2010
    Devon England
    273
    ive never had any luck cleaning them, GSF sell them for 165 which is a fair amount cheaper than genuine
    OWN A MK5 GOLF TDI JOIN THE GROUP http://www.vwaudiforum.co.uk/forum/group.php?groupid=23
  5. Re: Intake Manifold Flap Fault Codes and Cleaning
    197
    Cleaning the EGR valve and manifold is worthwhile, I use paint stripper and traffic film remover plus a lot of hard scrubbing. In my experience you will have to fit a new manifold flap.
  6. Thanks Eshrules thanked for this post
  7. The Following User Says Thank You to Crasher For This Useful Post:
    Eshrules (01-10-2010)
  8. Re: Intake Manifold Flap Fault Codes and Cleaning
    Aug 2010
    Hartlepool
    0
    I cleaned both the IMF and the EGR valve the other day. Do I need to replace the fuse again to check if it has made any difference?
    When I took it to a local indep VW garage for the VAG com scan they replaced the blown 10amp fuse with a 15amp. Is this likely to have blown?
    I didn't have time to take the manifold off. Is it easy to remove? Looked like there was about 8 hex bolts to losen on the front of it, it is as easy as that?
    I think the gasket on the EGR valve to manifold connection is a bit stretched as there is a slight hiss of escaping gas. Will probs replace the gasket when I take the manifold off and/or replace the flap motor.
  9. Re: Intake Manifold Flap Fault Codes and Cleaning
    Oct 2009
    Wiltshire England
    12
    Roughly how long will it take to change the manifold flap assy?
    I guess it would make sense to clean the egr valve too while I'm there, what gaskets would need to be replace when removing the egr(I would like to replace the if required to save any further strip downs)?
    Oh what is best to clean the egr valve something like carb cleaner or petrol?
  10. Re: Intake Manifold Flap Fault Codes and Cleaning
    Sep 2008
    chester
    9
    Take the flap and egr off together and split them on the bench its easier that way,as above, the flap gets oil carry over in the electrics and screws up the signal back to the brains,its not the crap in the visible areas, its behind the crimped cover.its easy to do with minimal tools.
  11. Re: Intake Manifold Flap Fault Codes and Cleaning
    Aug 2010
    Hartlepool
    0
    Quote Originally Posted by Buzzoff View Post
    Its pretty quick, I reckon I could do it in less than half an hour now I know what I am doing.
    Take off the engine cover, remove the air intake pipe to give extra room, unclip hose from bottom of IMF assembly. There are 2 cap screws secruring the EGR valve to the manifold, 2 securing IMF to EGR valve and 1 big one at the back that goes through both parts and in the the manifold.
    I cleaned mine with paint stripper and a few squirts of WD40, though I hear traffic film remover is good. I saw a bottle of this in the local pound store the other day so might use that next time when I replace the IMF.
    As far as gaskets, there is one between the EGR valve and manifold that I need to replace. Called the dealer and he needs a serial number to determine which one. If you buy a new IMF I believe it comes with the gasket for between that and the EGr valve.
  12. Re: Intake Manifold Flap Fault Codes and Cleaning
    Oct 2009
    Wiltshire England
    12
    Cheers for that, I guess I will need a new gasket between egr and the manifold if I am stripping it all down?
    Regarding "traffic film remover " is that available for the usual outlets such as euro, gsf or halfords (will it be found in the car cleaining area)?
    Oh I have also found this on the web, looks very helpful:
    http://www.audi-sport.net/vb/new-a3-...i-solve-2.html
  1. From a very fed up owner.
    By pistons in forum Fabia
    Last Post: 31-05-2011, 05:19 PM
  2. EGR and intake manifold cleaning 3.0 V6 TDI
    By Leoflavio in forum Phaeton
    Last Post: 12-10-2010, 09:08 AM
  3. Limp Mode
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-03-2010, 11:45 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Cleaning the Intake Manifold....
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 07:51 PM
Disclaimer: VW Audi Forum is an "independant enthusiast website", and is in no way related to any of the Worldwide Volkswagen,Audi,Seat,Skoda,Bentley,Bugatti,or Lamborghini group of Companies. For official upto date information on any of there vehicles, please visit the official websites. Any comments made throughout this website, are the views of the respective poster, and in no way represent the views of the VW Audi Forum Administration, or the worldwide Volkswagen & Audi Group of companies.
Copyright: Images used on this website by the Administration are "Copyright" of Volkswagen GB, Volkswagen AG (Germany), Audi GB, Audi AG (Germany), Volkswagen Motorsport GB, Volkswagen Motorsport AG (Germany), Audi Motorsport AG (Germany), Volkswagen Racing GB, Bentley, Bugatti, and Lamborghini. No image can be replicated by anyone WITHOUT the relevent Companies written permission.
VW Audi Forum is an AUTHORISED retailer for the Surf City Garage range of car care products
Page copy protected against web site content infringement by Copyscape
- VW AUDI Forum - The No1 VW Audi Forum - Volkswagen (VW) - Audi - Seat - Skoda - Bentley - Bugatti - Lamborghini - Porsche - VW Audi Forum -
