Thread: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 67
  1. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #51
    Feb 2013
    Moray
    Just a quick one guys, I've got all the parts for retrofitting cruise to my A4 (has a MFSW already), once i've done the hardware side of it could a VW garage code it? Seeing as it all the same group?
  2. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #52
    Nov 2009
    46 Post(s)
    I shouldn't see a problem tbh if you provide them with the info.
  3. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #53
    Feb 2013
    Moray
    That was kind of my thought process. As my nearest Audi garage is a 50 minute drive and the nearest person with VCDS is over 2 hours away :-\
  4. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #54
    Aug 2007
    Quote Originally Posted by Steve220 View Post
    I asked the same question at my local VW they said they could not complete the job as their diagnostic systems are web/online based and Audi are now brand inhibited to them so if they did plug my car in the software would realize this is not a VW and that would be the end of the diagnostics talking to the vehicle. On the other hand maybe they did not want to annoy Audi but I thought wrongly money would be money. I used an independent that had the software.
  5. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #55
    Jul 2008
    Southend on Sea
    Great thread,thank you,
    have now installed cc on my 2007 2.0d 140 Avant and coded the steering wheel module.
    Unfortunately my older version of vcds will not let me address engine module 01. Called Audi southend, they wanted an hours labour at £100+ to make the simple change, hopefully can call upon one of the newer VCDS/vagcom users here to help.
    Again thanks
  6. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #56
    Jul 2013
    Kendal, United Kingdom
    Great thread, and great to think this retrofit might be done so cheaply. One question that I don't think has been covered - will this work with the auto gearbox (JAX/HNL)? Apologies if this is a stupid question from a newbie
    Dave
    A4 Quattro Avant S-Line 3.0TDi auto - remapped to 265BHP
  7. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #57
    Jul 2013
    Sorry - I could have answered my own question simply by looking in the owners manual . Yes, cruise control is an option on the auto models and therefore there's no reason why it can't be retrofitted either.
    Dave
  8. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #58
    Jun 2012
    Bristol, UK
    Hi all! Sorry for my english! I just installed a new steering wheel modul part num ending Q to support Cruise control, and installed the stalk, and after enabled cruise control in engine modul, and added cruise control in steering wheel modul, and fixed ESP fault, the cruise control not work... even if i drive, or the cruse control sign on the dash... I had read the cruse control switch blocks in engine modul, and all functions works on,off,set,+,-,.... any idea what is wrong? Thanks!
  9. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #59
    May 2007
    knee deep in clunge
    14 Post(s)
    check the clutch switch status in address 01 may be measured block 6 but not 100% the switch status must change from 1 to 0 pressed/unpressed if it shows 1 all the time replace the switch as the ecu reads the status of 1 as clutch engaged cruise de activated
    so 16 coded correct and address 01 cruise login enabled
  10. Re: Retrofitting cruise control to A4 quattro - possibly the best thread on this subject covering all issues from the basic to the complex.
    #60
    Apr 2015
    Chesterfield, England
    Hi, this is my first post here, had my A4 around a week and loving it.
    I'm just in the process or procuring the parts required to retrofit cruise to my B7 A4 Avant.
    I am obviously aware the car will need to be hooked up and the cruise enabled for it to work.
    So for my questions;
    Where can I get this done, NOT Audi as they want £275 to fit and code it,
    Is there anyone local (ish to me) NE Derbyshire / S Yorkshire that could do it for a reasonable price just the coding
    I'm considering Buying VAGCOM or whatever its called now, is that capable of doing it?
    Thanks in anticipation
  1. How To retro fit cruise
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-03-2010, 01:34 PM
  2. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  3. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
