Thread: Can I clear the fault codes with shareware VAG-COM?/Error Code- Potentiometer for EGR
  1. Can I clear the fault codes with shareware VAG-COM?/Error Code- Potentiometer for EGR
    As title
    Oct 2005
    Nope, you can only read them.
  3. Error Code- Potentiometer for EGR?? Implausible signal
    When I ran the dionostis Vag-com programme on my Polo 6n ,an engine error code ... P1444 came up - potentiometer for EGR - Implausible signal.
    any ideas how i can address this myself?
    http://www.ross-tech.com/vag-com/vag-functions.html
    Thanks for reply- according to this i can- ?
    Oct 2005
    So you can, I was wrong.
    It's reading them all you can't do with the free version
    Quote Originally Posted by ardasaliah View Post
    LOL why didnt you read that in the first place then :P as far as i am aware, certain codes only can be read and cleared the more 'technical' codes are only read in the full version.
    the other option if you want to do a full diagnostic is to get a code reader, around £30, but for what its worth, you may as well outlay for the vagcom license
    Quote Originally Posted by eshrules View Post
    The reason I asked was -that I recently cleared a code and after a while it keeps popping lighting up again. I think I have fixed the problem but the light comes back on after a while-Can't get rid of it.
  1. Error Code- Potentiometer for EGR?? Implausible signal ??
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-01-2008, 09:57 PM
  2. Error Codes
    By andyd118 in forum Audi A4 - Archive Topics
    Last Post: 18-05-2007, 10:33 AM
  3. Vag-Com : clear fault codes
    By keland in forum VCDS - General Questions
    Last Post: 11-05-2007, 09:43 PM
  4. Vag-com Error codes... Help??
    By Beezo75 in forum VCDS - General Questions
    Last Post: 10-05-2007, 10:26 PM
  5. Does disconnecting the battery clear the error codes/logs ?
    By MiKe_T in forum Passat - Archive Topics
    Last Post: 22-01-2007, 09:00 PM
