Thread: Flashing Glow Plug Light??
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. Flashing Glow Plug Light??
    Dec 2006
    After refueling today, the glow plug light has since started flashing constantly. When I initially started the car on the forecourt, it stopped, but there was no trouble starting it again. The handbook says that when this light flashes it indicates a fault with the diesel engine management system and that it should be taken to a dealer ASAP. Has anyone had this? Is it okay to drive? Or is it simply a new set of plugs needed? Cheers.
    south wales
    mines been flashing for the last 50k i dont even notice it anymore the car still drives as it always has. now and again it stops flashing only then do i notice it
    i was told that it was dirty diesel that started mine off althrough im not sure how true that is.
    ive also been told its because the break lights are not working but they are. maybe worth checking them through.
    7 Post(s)
    9/10 times this is due to a dud brake light switch.
    Apr 2007
    Quote Originally Posted by TDi_B5 View Post
    if you get the little engine workshop message then try your breaklights if they both working fine just take them out give the connection a good clean and put back in, thats what i done and it was fine!!
    Jun 2006
    UK, Mids
    It means a critical fault is present, you should have the codes read.
    The glow plug light doubles up as the EML on the TDis.
    Feb 2007
    im fascinated with the recent threads, EML? engine management light?
    why does a dud brake light, throw up a glow plug issue?
    Dec 2006
    Quick update. Took the car into Skoda today (VW were fully booked), they had it for just under 2 hours. They ran a full diagnostic check, cleared the fault codes and then took it on a 5 mile run, which has stopped the light from flashing. Looks like it may just have been a glitch, car is running as it always has done. I am also intruiged by the brake light/switch idea though??!
    Jun 2006
    UK, Mids
    What were the faultcodes?
    Dec 2006
    I wasn't told what the codes were and after waiting in the showroom for two hours I was quite keen to leave!
    Dorset
    Hi all, I had the same problem and mine was due to a brake bulb coming out and causing a short which must have caused two other brake bulbs to blow, replaced blown bulbs and all is well now. Cant beleave VW scare the hell out of you with the computer saying "Engine Workshop". when mine happened I turned straight round and got home asap only for someone to say "mate your brake lights aint working"
    Jimmer
  1. A4 TDi - glow plug light flashing, will not rev up past idle speed
    By tom fenton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 07:49 PM
  2. Glow plug warning light flashing.
    By Nebooaw in forum Passat - Archive Topics
    Last Post: 06-07-2007, 07:37 PM
  3. Fault Code p0200 (flashing glow plug)
    By s0niX in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2007, 05:32 PM
  4. Glow Plug Warning Lamp Flashing
    By apache24uk in forum Polo - Derby - Lupo - Fox
    Last Post: 10-04-2007, 09:20 PM
  5. Glow plug warning flashing whilst driving
    By Linndek in forum Archive posts
    Last Post: 16-02-2007, 02:50 PM
