Thread: radio code enetery instructions for audi delta
  1. radio code enetery instructions for audi delta
    hi can anyone tell me what the procedure is to enter the radio code , mine is a Delta Radio in a 97 A6 avant
    thanks
    Apr 2007
    Lancashire
    This is the procedure for entering the 'Delta CC' code, courtesy of Ti Kan:
    Entering anti-theft code
    The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
    1. Turn on radio. The radio display shows "SAFE".
    2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
    3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
    4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
    5. The radio should unlock and be usable shortly afterwards.
    6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
    7. If you lose your radio code, contact your Audi dealer.
    http://www.ibiblio.org/tkan/audi/radios/deltacc.html
    http://www.ibiblio.org/tkan/audi/radios/radios.html
  3. big thanks
    thankyou very much !!!, am off to try it now
  4. wicked!!!
    It works , thankyou again!!!!
  1. VW Golf Mk4 Radio (Gamma) Instructions
    By ch8rt in forum Chat - Completely Off Topic
    Last Post: 27-11-2009, 04:40 PM
  2. Delta radio in Golf Mk4
    By tr85858 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-06-2007, 09:44 PM
  3. VW Radio Code
    By ian999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-05-2007, 09:52 PM
  4. audi a4 gamma radio code install
    By bobby b in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-02-2007, 12:32 AM
  5. Audi Radio Code
    By eribar in forum Archive posts
    Last Post: 30-06-2006, 11:07 AM
