Thread: Rear Left ABS 00290/00668
  1. Rear Left ABS 00290/00668
    Mar 2018
    chester,england
    Scratching my head.
    Car ABS light come on, then started flashing with the Red Exclamation Mark.
    Plugged in my scanner and come up with Fault Codes 00290 and 00668.
    Figured it'll just replace the sensor and that will be that.... Picked up the part from local Car Parts Store (LVW)
    However, never bloody simple with an 18 year old car is it.
    The ABS light has remained on and the Red Exclamation mark of doom has too.
    Reluctor Ring looks good. There's no wheel bearing noise. And there's a voltage to the wire that connects to the wheel sensor.
    I'm rather stumped, proper begrudge paying garages money too!
    Any other ideas appreciated
  2. Re: Rear Left ABS 00290/00668
    1841 Post(s)
    So do you “proper begrudge” taking free advice from a garage owner?
    You have replaced the rear left speed sensor but which code has come back after clearing the codes after the repair, the sensor itself or the low ECU voltage?
  3. Re: Rear Left ABS 00290/00668
    Mar 2018
    chester,england
    Didn't mean it to sound harsh, it's just I do all my own car work, home DIY, gardening etc as I've got things to pay for.
    Yes, Replaced the sensor. Took the Voltage reading from the part of the wire/loom that plugs into the sensor. No other codes relating to any of the other wheels etc, so just has me stumped.
  4. Re: Rear Left ABS 00290/00668
    Jan 2009
    Nuneaton England
    6 Post(s)
    What fault code have you got?
  1. Rear left and right LED fenders.
    By sam2k01 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-04-2017, 11:06 PM
  2. squeaking rear left
    By accy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2009, 11:26 PM
  3. T5 00668 VAG fault code?
    By andy8442 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 01-05-2009, 03:48 PM
  4. bad camber in rear left side
    By JB1666 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-05-2008, 11:24 PM
  5. knocking at the left rear
    By NIgolf in forum Passat - Archive Topics
    Last Post: 26-03-2007, 10:09 AM
