Thread: Reduce oil???
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Reduce oil???
    Apr 2017
    London UK
    10 Post(s)
    Hi, I’ve searched for this but not found anything so apologies if it has come up already. My Q7 has started showing a reduce oil level message, though no oil has been added for some time. Is this just likely to be a fault with the sensor? Has anyone else had this issue? Thanks.
  2. Re: Reduce oil???
    Jan 2016
    Co Durham
    15 Post(s)
    If you have milage and how you drive you may get a more informed reply. I used about 1lt in 7000 miles but I did short journey driven in quite a sympathetic manner.
  3. Re: Reduce oil???
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I've seen this high oil level on a BMW, it could be the same in your case; if you do shorter trips with engine not getting fully up to heat and active dpf regens the change in diesel injection timing ( injecting diesel on exhaust stroke I think) can end up washing down cylinder walls into the sump and dilute oil and raising level.
  4. Re: Reduce oil???
    Jan 2016
    Co Durham
    15 Post(s)
    Sorry I read it as reduced oil. A trip to the dealers me thinks.
    Quote Originally Posted by DL78 View Post
  5. Re: Reduce oil???
    May 2012
    Everywhere
    308 Post(s)
    More common sense marques have an injector post engine to heat up the dpf .
    What we're the others thinking...
  6. Re: Reduce oil???
    Nov 2014
    Nottinghamshire
    Had it on my SQ the other week. Did some searching and probably being caused by doing short runs - or not enough longer runs. I took mine out for an hour and the warning remained on, but when I got back in after an hour or 2 it went off and has not been on since. Mine's not had any oil in since new. Only done 8k miles though
  7. Re: Reduce oil???
    Nov 2010
    104 Post(s)
    Fuel dilution of oil reduces viscosity and accelerates engine wear, another good reason not to leave oil change services to 20,000 miles.
  8. Re: Reduce oil???
    Apr 2016
    Stansted
    169 Post(s)
    I’ve just started getting this warning. Will try and get a long run in this week to see if it goes away!
    Former Q7 owner
  9. Re: Reduce oil???
    Nov 2014
    Nottinghamshire
    Quote Originally Posted by srbsq7 View Post
    Had it on mine a few times. I reckon it's low usage, or seemed to be the case with mine. I have now swapped the SQ7 over to a Q8 3.0 and not had it on this one - yet!
  10. Re: Reduce oil???
    Jan 2020
    York
    Have you tried opening and closing the bonnet know it sounds daft but has worked sometimes there is a software upgrade also if you don’t have a dipstick you can get them of amazon and not mega expensive always a good buy for piece of mind.
  1. Question Please reduce engine oil - NIGHTMARE
    By Pete_NorthEast in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-02-2018, 10:44 AM
  2. Please reduce engine oil
    By Redcar01 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2016, 06:39 PM
  3. Reduce oil warning
    By DrNorthy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-03-2014, 11:34 AM
  4. Please Help Must reduce HC emissions
    By glenoaks in forum Chat - Anything with wheels
    Last Post: 22-10-2009, 06:28 PM
  5. Reduce emissions
    By cbrpaul in forum VCDS - General Questions
    Last Post: 05-05-2008, 02:47 PM
