Thread: VW T5 Vacuum pump readings
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: VW T5 Vacuum pump readings
    1842 Post(s)
    There are a lot of Bosch forgeries around, check the sticker to see if it is made in China. I won't trust anything other than an AMM from TPS and even they can come faulty out of the box. Check the operation of the VNT rod in Basic settings 011.
  2. Re: VW T5 Vacuum pump readings
    Jun 2018
    leeds
    hi, been reading this thread with great interest, as it came up in my internet search for the pump readings, yestdarday i was sat at the garage yet againm and my van had very similar problems and 2 garges could not sort it, long and short very similar to above post although his was 2 years ago and must now be sorted but no reply to the outcome so we had to do more work, as a stroke of luck we found my personal problem thats why im posting this as maybe help somone in futre, in the end the mechanic had the non return valve tested it all good, but we think was a copy as he turned it around and the van got full power and brakes back?? he took it off again to check and the arrow (flow) was facing the wrong way for the van to work correctly, if fiited with arrow in vacum flow direction, the van was usless. hope this helps as i nearly sold the van i was that sick of spending money and none of it worked. yesterday was my lucky day, i hope you all lucky.
  1. vacuum pump
    By abby1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-12-2014, 02:29 PM
  2. Question Vacuum Pump?
    By geordiestig in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-01-2014, 07:21 PM
  3. How To Exhaust vacuum pump
    By Nemo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-03-2012, 01:19 PM
  4. Vacuum pump (tandem pump)
    By audi_130bhp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 12:44 PM
  5. electric vacuum pump
    By gaz238 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2007, 04:45 PM
