Thread: Fault code 462c
  1. Question Fault code 462c
    My wife's passats turbo has been cutting out and we've had a scan done and the code is 462C and it came up with 'Boost pressure control below limit'
    Can anyone tell me if this is a serious problem relating to turbo charger or is it the thrust sensor etc etc??
    Any help appreciated
  2. Re: Fault code 462c
    Think the code can also be interpreted as 17964???
  3. Re: Fault code 462c
    17964/P1556 - Charge Pressure Control: Negative Deviation
    Possible Symptoms
    • Reduced power output
    • Limp mode
    Possible Causes
    • Boost Pressure too Low
    • Hoses/Pipes incorrect connected, disconnected or leaking
    • Charger Pressure Control defective
      • VNT (variable nozzle turbo): nozzles stuck
    • Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    • Check Hoses/Pipes to/between Components
    • Check Solenoid Valve for Boost Pressure Control (N75)
    • Check / Clean / Replace Charge Pressure Control
      • Check / Clean mechanism for variable nozzles
    when you say cutting out , do you mean its been going to limp mode ???? or is it stalling all together?
  4. Re: Fault code 462c
    Norfolk
    Check that none of the fat tubo pipes is split or undone. Check that the turbo actuator lever moves about 20mm when you start up. If it doesn't replace all the little vacuum pipes.
  5. Re: Fault code 462c
    Thanks for your suggestions. It's been going into limp mode and the turbo has been cutting out.
    Have been told maybe the MAP sensor or N75 valve. Will check the actuator rod tomorrow, it feels a bit stiff. Is this something that has to be accessed from under the car on the B5 passats.??
  6. Re: Fault code 462c
    Norfolk
    You don't need to touch it. Just watch to see it move when someone else starts the car. Faulty MAF doesn't usually give your fault code. N75 valves rarely go wrong. Far more likely to be a faulty intercooler hose (the fat hoses) or a faulty vacuum hose (the little thin hoses). The MAP sensor is more likely to fail than the N75 valve.
  7. Re: Fault code 462c
    from my experience it was the MAP that failed £49 at dealers , but my new blue and red silicone hoses do look pretty .
    id think low turbo pressure was maybe more down to a holed pipe as martin says , martin helped me with my faults for 3 days , i plagued the life outa the poor man - he-he. but he loves helping folks with mending the cars as do i .
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. Code Fault Recognition
    By csducks in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-01-2010, 10:10 PM
  3. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  4. gearbox isolator switch??????
    By a25c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 11:29 PM
  5. Please Help Climatronic Fault Code.
    By gbdxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2009, 04:49 PM
