Thread: Diagnostic code
  1. Diagnostic code
    May 2010
    mk
    Hi all.
    The mrs has a 55 Toledo 1.9tdi sport. Last week whilst out and about the car went into limp mode. When she got to her destination she turned the car off. About an hour later she drove the vehicle and it was fine and was so for a day or so.
    On Saturday it went into limp mode again, and then again on her next journey and on every journey (she is a carer so is going from one client to the next all day long). Anyway, she called kwick fit (for reasons only she can justify in her head) and they diagnosed fault 379. This is apparently 'boost pressure control deviation negative'.
    They also said that the car has a screw on the turbp which can be adjusted to increase boost and that the previous owner may have done this whilst they ran it and turned it back to sell it and that may have created this problem.
    She bought the car back in May 09 and has done 40K in it to now without any major issues.
    Is this a real dignostic code and does any of the above mean anything to anyone? WHat would our next step be?
    Any help is much appreciated!
    thanks
    Col
  2. Re: Diagnostic code
    Jan 2009
    towcester northants
    boost pressure control deiation is a fault
    but 379?
    get vagcom check and see what it says and go from there
    where are you in mk? im in mk on wed morning!
  3. Re: Diagnostic code
    May 2010
    mk
    we live in Stantonbury Fields near Linford Wood
    what time Wednesday would you be in MK?
    P.S will it do the car any damage to still drive it?
    thanks Colin
  4. Re: Diagnostic code
    Jan 2009
    towcester northants
    im in wymbush area in the morning
    doing small service on my mates citreon
    give us a call 07711 523638 and will pop round to do diag test and advise
    if its going into limp mode it does this to stop any damage so should be ok
  1. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  2. Question Non of the electricals working on the left side of my 2005 mk5 gti
    By Moeg5 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-04-2010, 07:59 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  5. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
