Thread: A6 Front Brake Pad and Caliper Rattle
  1. A6 Front Brake Pad and Caliper Rattle
    May 2010
    Macclesfield Cheshire
    Hi, I am wondering if anybody can help me, I recently had new brake pads fitted at kwick fit, a couple of weeks later I got a really bad metal sounding rattle from both front wheels.
    When I took them back to Kwik Fit they said it was probably because they where not genuine audi items that they fitted, so they ordered the genuine audi pads and refit them free of charge, however they still rattle terribly on bumpy services. Sound like something is about to go very wrong.
    The pads are secure and we have no rattle when brakes are applied, the discs are in fine condition and the car brakes very true.
    The guys at Kwik fit showed me, they are secure its just like they are the wrong size and need some sort of spacer or spring ???
    They are baffled and when they rang our local Audi dealer they said I would have said to bring it to them, however im skint.
    Its a 2005 audi 2.7 tdi avant sline if this makes any difference!!
    Any advice would be appreciated.
  2. Re: A6 Front Brake Pad and Caliper Rattle
    What brakes do you have FN3 with a wire anti rattle spring or FNRG60 with a flat section machined spring.
    Did they fit the right pad each side. The pads are marked with an arrow to show the direction of rotation of the front wheel. Ask Them. Regards Peter
  3. Re: A6 Front Brake Pad and Caliper Rattle
    Can you describe the noise better and do you know if they removed the adhesive backing from the outer pads. Regards Peter
  4. Re: A6 Front Brake Pad and Caliper Rattle
    May 2010
    Hi I'm affraid I am not technical, but they did seem knowledgable at kwik fit and took the wheels off and showed me thatbthe callipes where robust and the pads sat in flush.
    I will ask them the question regarding the type of pad, as above and your comments maybe the incorrect pad was fitted as it's as though it needs an anti rattle spring pad
  5. Re: A6 Front Brake Pad and Caliper Rattle
    You still have not described the noise. You need to establish the type and make of the caliper is it an FN3 ATE. If you rotate the alloy you can see the caliper and the spring. Regards Peter
  1. "How To" Front brake pad/disc replacement
    By bora(ing) nick in forum Volkswagen
    Last Post: 24-06-2011, 12:05 PM
  2. Rattle off side front brake/wheel, on Quattro
    By The Cambelt Kid in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-05-2009, 08:13 PM
  3. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  4. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  5. A4 Front Brake Pads
    By mrp727 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2007, 06:42 PM
