Thread: Passat aerial amplifier fault
  1. Passat aerial amplifier fault
    Apr 2010
    Lockerbie Great Britain
    Hi just new to the forum,
    have a fault with my aerial amplifier ( full of water )
    checked for a 12 volt feed at the short lead at the gearstick,
    only shows 12 volts when radio switched off then on for about 6 secs
    is this normal or a fault with radio ? ( checking at middle of aerial lead )
    does radio have to see a load if not disconnects live feed to amplifier ?
    Passat 2001 with factory fitted radio
  2. Re: Passat aerial amplifier fault
    Jun 2006
    UK, Mids
    Interesting, I had this problem at the aerial when I measured the voltage. I replaced the aerial base (which was just corroded) and still have rubbish reception, so gave up as I don't use it much.
    Audi A8 - 2015 - 3.0TDI
  1. passat tdi - aftermarket cd/mp3 player - amplified aerial
    By hoffmeister in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2009, 05:57 PM
  2. Passat fault codes
    By bigiveaudi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-08-2009, 11:10 PM
  3. 2006 A6 Battery issues
    By wmccann in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2009, 04:08 PM
  4. 2001 Passat TDi 130 Engine running fault nightmare
    By Passatnightmare in forum Chat - Anything with wheels
    Last Post: 05-08-2008, 08:48 PM
  5. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
