Thread: Tailgate doesn't open on my A4 Avant
  1. Tailgate doesn't open on my A4 Avant
    Dec 2007
    Folks, not sure about this one. Yesterday I couldn't open the tailgate on my 2004 Avant TDI. I could hear the solenoid/mech working but only half it simply didn't want to pop open.
    It happend a couple of weeks back when it was also a very hot day like we had yesterday by the evening once it had cooled down it was fine.
    Is this a known problem for these?
    Cheers.
  2. Re: Tailgate doesn't open on my A4 Avant
    May 2010
    salisbury uk
    Hi im looking for the same anwser as mine is doing the same, ??? also an 2004 advant 1.9tdi
  3. Re: Tailgate doesn't open on my A4 Avant
    Dec 2007
    Aberdeenshire, Scotland.
    Can you open your tailgate with the key? If you can, pop the door trim off and check if the solenoid is moving and that the metal bar is properly attached.
    If the bar is attached, you probably need a new solenoid unit.
    Check this how to guide here-
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=43465
    2009 A4 Avant TDI SE 143 in Garnet Red, Cruise, Start/stop, Bootliner.
  4. Re: Tailgate doesn't open on my A4 Avant
    May 2007
    Under the Forth Bridge
    Not the most technical of answers, but I used to have problems with my back doors (which weren't used very often) during very hot weather. The rubber seals became quite sticky and you wouldn't believe the effort to pull them open.
    Give the seals a quick once over with a damp soapy cloth when you have the tailgate open next - you never know. Could be a two minute job that saves a lot of frustration and further investigation.
  5. Re: Tailgate doesn't open on my A4 Avant
    Only to also add that i have a 2004 A4 Avant and have exactly the same problem. Its been more noticeable this year with the good weather. It wont open with the fob either. As soon as the weather cools down it opens. Its really annoying when your stood their with all your shopping.
  6. Re: Tailgate doesn't open on my A4 Avant
    Jun 2009
    Cheshire
    This happened on my Avant when the car got very hot on a trip to Portugal. It then became a more regular happening.
    If you can crawl into the boot space there is a red tab in the emergency triangle space which when pulled will manually release the catch.
    I changed the solenoid which was fairly straightforward and from memory only about £25 for a new solenoid. Never had a problem since
  1. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  2. Pick up my A4 Avant this Saturday
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-10-2006, 05:35 PM
  3. Replies: 0
    Last Post: 05-03-2006, 07:58 PM
  4. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
