Thread: Mk4 tdi pd Low power and when engine is hot/long distance drive
Results 1 to 8 of 8
  1. Mk4 tdi pd Low power and when engine is hot/long distance drive
    Mar 2010
    harlow-essex
    Hi guys,
    Noticed a problem with my golf mk4 tdi pd....Been driving to London twice in the last month and every time ,Towards the end of the journey when egline is hot and only at slow speeds lack of power...or when going uphill,1st gear,second 3rd and I have to rev the **** out of it but lacks power still...I normally change gears around 2000 rpm.Strangely at high speeds on the motorway it s very responsive.I hear the turbo every time plus I ve changed the Maf today wich I bought from a vw dealer in kent but still no change.Another thing I had for the first time to day is a workshop emissions message on the dashboard(disconnected the batery for 1 hour but it was still there) wich finally dissaperd after a few hours.
    The sansation is the same as if I would have one of the spark plug disconnected on a petrol engine.Can it be a glow plug?
    Thank for your replies,
    Alin
  2. Re: Mk4 tdi pd Low power and when engine is hot/long distance drive
    Southampton, UK.
    Could be an injector wiring problem. See here for a recent thread: https://www.vwaudiforum.co.uk/forum/s...d.php?p=518486
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: Mk4 tdi pd Low power and when engine is hot/long distance drive
    Sep 2007
    Plymouth
    Is the temparature gauge stable - does it alter alot whilst driving? Suggest you get a fault code read somewhere as this will help a great deal in pinpointing the issue.
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  4. Re: Mk4 tdi pd Low power and when engine is hot/long distance drive
    1837 Post(s)
    You need a code read.
  5. Re: Mk4 tdi pd Low power and when engine is hot/long distance drive
    Mar 2010
    harlow-essex
    Thank you for your replies guys,in order to avoid dealing vith dealers that don t care or don t have a clue I ve oredered a genuine vcds from ilexa and will get it tommorow...I am not a mechanic but I ll use it to check it and if there will be something Ill be able to do without complications I ll do it myself...but at least i get to know where the real problem is.
    Re Temperature...no problems there I thing it stays always at 90 constantly.
    Had a chat with a guy from to day and he told me straight away that it might be the injector wiring..but we ll see what vcds says.
    Regards
  6. Re: Mk4 tdi pd Low power and when engine is hot/long distance drive
    1837 Post(s)
    That is a very good decision, Ilexa are great people and with genuine VCDS a lot of people on this forum and the Ilexa forum can help you in at the very least diagnosing many electronic issues that will help you be more aware when you employ the services of a mechanic.
  7. Re: Mk4 tdi pd Low power and when engine is hot/long distance drive
    Mar 2010
    harlow-essex
    Right guys got the vcds from ilexa now ...2 errors found here we go.
    1 Fault Found:
    17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
    P1144 - 35-00 - -
    Readiness: 0 1 0 0 0
    and the 2nd
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 A
    Component: 27 AIRBAG VW51 01 0008
    Coding: 12855
    Shop #: WSC 01266
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Problem is Ive replaced the maf 2 days ago....but still no chANGE.Any ideas?
    Translation ?
  8. Re: Mk4 tdi pd Low power and when engine is hot/long distance drive
    1837 Post(s)
    Clear the codes and run it around again for a few days and then read the codes again. The 17552 is probably someone disconnecting the Air Mass Meter (MAF) with the engine running. The air bag code will just be due to a flat battery sometime in the past since the codes were last cleared.
