Thread: Audi A4 2001 2.0 petrol timing chain
  1. Audi A4 2001 2.0 petrol timing chain
    May 2010
    Midlands
    Hi, does anyone know what milleage the timing chain needs to be replaced? also is replacing the time belt tentioner a big/expensive job as it is noisey on start up for a few seconds. Hope you can help.
    Many Thanks
  2. Re: Audi A4 2001 2.0 petrol timing chain
    Oct 2005
    The timing chain is actually a belt and the general consensus is to replace it every 60,000 miles or 4 years - While Audi UK suggest otherwise, failure does happen and will cost you £££.
    It's a fairly big job (front end off etc) and yes, you should replace the tensioner and water pump.
    My Passat is also a 2001 2.0 petrol and I've had two belt changes.
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  3. Pricing Set For Uk-bound Audi Tts Coupe And Roadster
    Last Post: 13-02-2008, 08:03 PM
  4. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
