Thread: egr valve position and removal passat 2.5 v6 tdi
  1. egr valve position and removal passat 2.5 v6 tdi
    Apr 2009
    manchester
    Hi I am wanting to clean my egr valve out and am pretty sure where it is but would just like somebody to tell me if I am right and how to go about removing it,and do I need new gaskets?
  2. Re: egr valve position and removal passat 2.5 v6 tdi
    Jun 2006
    UK, Mids
    It is where the right hand silver 'flying saucer' is. (that is the top of it)
    The other one is the turbo, (usually covered with heat shield).
    Alternatively, you can blank it off where the braided pipe meets the aluminium inlet manifold at the bottom of the picture under the socket extension. You can use a gasket as a pattern.
    Audi A8 - 2015 - 3.0TDI
  3. Re: egr valve position and removal passat 2.5 v6 tdi
    Apr 2009
    manchester
    thanks for that it is the one i imagined
  4. Re: egr valve position and removal passat 2.5 v6 tdi
    Jun 2009
    Kenilworth UK
    I have managed to crack off 3 of the 4 fixings to remove the EGR I intend to replace. However, how on earth do you loosen the 4th fixing next to the inlet manifold. My fingers don't want to bend the 6 ways needed!! Do I need to bend something or remove something else to get access?
    2003 A4 2.5 tdi
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Power window problem
    By erico in forum Early Passat Forum - Pre 97
    Last Post: 19-04-2008, 09:25 AM
  4. "How To" Change The Fuel Filter in a Mk4 Golf TDI
    By chris.fulton in forum Volkswagen
    Last Post: 06-02-2008, 05:43 PM
  5. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
