Thread: Fault code 18047 Passat tdi
  1. Unhappy Fault code 18047 Passat tdi
    Nov 2008
    Hi i have Passat tdi 115bhp 2000 model it goes to limp mode usually on motorway,Revs drop to 1200 revs, if i turn off and restart fault clears. I have put my scanner on and its come back with 18047 fault code , which is accelerator pedal position sensor! So do i replace the sensor on the pedal or is it something else causing the fault? Any info please as its doing my head in
  2. Re: Fault code 18047 Passat tdi
    Jan 2009
    towcester northants
    you need to check voltages at pedal
    i must admit the last one i done was due to water ingress into pedal and connections
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  3. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  4. passat 2.0se 2001 fault code
    By mendit in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 10:55 PM
  5. Passat TDi - ANOTHER Alarm Fault (help!)
    By EdF in forum Archive posts
    Last Post: 06-01-2008, 05:13 PM
