Thread: Leaking water pump
  1. Leaking water pump
    Apr 2009
    Hi all
    Question to you knowledgable folk!
    I have a '96 1.6 Polo and the coolant has emptied twice in the last 10 days over a distance of approx 350-400 miles.
    I noticed it when the temp gauge light was flashing, although the temp was staying in the middle.
    Upon checking after the second time i found a couple of drops under the water pump.
    I filled the tank and ran the engine, it took a while then a few drops came out. Have tightened the screws and appears to have slowed it greatly.
    Would this point to a split gasket in the pump? if so, is that easy to replace or is it best to fit a new pump? either way, how easy is it for a novice?
    Many thanks in anticipation...
    with more queries to come
  2. Re: Leaking water pump
    Apr 2009
    Problem solved!! (hopefully)
    I have put down the extra leaking to an overflow, the level has stayed the same now after a bottle of K weld.
    200 miles later still ok
  1. Please Help plenum chamber - water in engine?
    By deezal in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2010, 12:31 AM
  2. Household water - A puzzle!
    By stuart in forum Chat - Completely Off Topic
    Last Post: 09-02-2010, 09:51 PM
  3. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  4. Failed Water Pump??
    By Degsy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-04-2009, 05:34 PM
  5. Polo Cooling system
    By nigell in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 09:35 PM
