Thread: 2.5tdi Cylinder Compression
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. 2.5tdi Cylinder Compression
    Burnley, United Kingdom
    I am trying to find the cause of the smoke billowing from my A6 Avant. I have checked the crankcase breather, all is clear, the inlet to the turbo is super clean and there isn't any play in the turbo.
    I plan to do a compression test but cannot find any info regarding what the spec should be.
    Can anybody provide me with the relevant information?
    The car is a 1999 C5 Quattro Avant 2.5tdi V6
    Regards,
    E
  2. Re: 2.5tdi Cylinder Compression
    Aug 2007
    Hook Hampshire
    21 Post(s)
    If black smoke from the exhaust then this can be turbo problems or leaks in the turbo pipework. If the turbo is fine and i am not sure how you check the turbo, then air leaks in the pipework or the intercoller can lead to lack of air and an over rich mixture and hence smoke.
    Vagcom should be your first port of call
    Audi A7 3.0TDi 2011 180k miles, engine code CLAB 204bhp 2WD
  3. Re: 2.5tdi Cylinder Compression
    Quote Originally Posted by shabazmo View Post
    Thanks for the response. It isn't black smoke I am getting (black would indicate a fuelling issue).
    I am getting blueish / whiteish smoke that smells distinctly of oil.
    There could be an issue with the turbo, just because there is no play in the shaft, it doesn't mean the seals are OK.
    But, I fear that the engine is just tired, a compression test would confirm, I just don't know what the sort of pressures are normal / abnormal.
  4. Re: 2.5tdi Cylinder Compression
    Sep 2009
    A406
    Can you post engine code, that way is more chance someone will post you info regarding compression...
    V6 Tdi Power!
  5. Re: 2.5tdi Cylinder Compression
    Quote Originally Posted by All-rod View Post
    aaahh Yes, I knew I must have missed something.
    I believe the engine is an AFB variant.
    E
  6. Re: 2.5tdi Cylinder Compression
    135 Post(s)
    2036 Post(s)
    Take the cam covers off and inspect the cams for wear.
  7. Re: 2.5tdi Cylinder Compression
    I am aware that the cams are somewhat of a weak point in these engines, material spec of cheese I understand.
    I don't see how worn cams will cause smoking though, a drop in power and poor fuel consumption maybe.
    E
  8. Re: 2.5tdi Cylinder Compression
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Although blueish smoke suggests burning oil, I have not come accross cases where the block has worn. They tend to be bullet proof.
    White smoke tends to represent unburnt fuel, so if cams are severely worn, the valves are not lifting as much as they should, and the cylinders are not sucking in as much air as they should. This leads to poor compression. Poor cmpression leads to poor fuel burn and therfore white smoke. The smell could be unburnt diesel rather than oil. To do a compression test the injectors have to come off and to do that the cam covers have to come off. So suggest you do as Crasher suggests. Look at the cams.
    Best of Luck. it could be expensive
  9. Re: 2.5tdi Cylinder Compression
    19.5 to 1 but I do not think that will be the issue. I suggest you read the ID label in the spare wheel bay to ensure you have the right engine code. Disconnect the feed into the bottom of the intercooler and see if is storing excessive oil indicating a leaking turbo. How many miles has it done. Regards Peter
  10. Re: 2.5tdi Cylinder Compression
    Quote Originally Posted by Peter D View Post
    Hi Peter,
    Thanks for the info, but it is not the engine compression I am after but the cylinder pressure.
    E
  1. mk 4 golf
    By claireg713 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-01-2010, 02:55 PM
  2. Low compression on one cylinder
    By ncc1701.js in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 09:27 PM
  3. 1.4 Low compression in cylinder 3
    By eethon in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2009, 09:05 AM
  4. Mark IV 1.4 Oil consumption
    By Gravesie in forum Golf MK4 - 1999 - 2004
    Last Post: 14-09-2007, 02:36 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
