Thread: Is it safe to drive ?
Results 1 to 10 of 15
  1. Is it safe to drive ?
    Mar 2010
    guildford
    Hello all, have a very unusual problem. My Bora 130 has started to blow cool air from the heaters. when i lifted the bonnet and checked the water pipes did not seem to have any pressure in them as if the water pump was not circulating the water. however the car did not loose any water and did not run hot even on a drive back from ireland . no loss of power and everything else seems fine. anyway i have decided to have cambelt/waterpump done and was wondering if it is safe to drive it to the garage (about 20 miles) without doing any damage. Cam belt last done 18,000 ago when i bought the car but have a feeling the water pump was not changed . learned lots about my baby for this site, keep up the good work.
  2. Re: Is it safe to drive ?
    middlewich uk
    Funny one for us to anwser just incase anything did happen if you where told it would be ok, me personaly i would see if the garage could collect the car as most do now.
  3. Re: Is it safe to drive ?
    Mar 2010
    guildford
    thanks for your reply. it bizare how the car got back from ireland with no probs. maybe i had the luck of the irish with me. will ask if the garage will come and pick it up. cheers
  4. Re: Is it safe to drive ?
    Mar 2010
    guildford
    Quote Originally Posted by eric black View Post
    thanks for your reply. It bizare how the car got back from ireland with no probs. Maybe i had the luck of the irish with me. Will ask if the garage will come and pick it up. Cheers
    is it possible for the car to have a broken water pump and no over hearting problems?
  5. Re: Is it safe to drive ?
    middlewich uk
    Not really, are the water pipes getting hot? could it be a problem with your heater? is your car temp still running at 90c??
  6. Re: Is it safe to drive ?
    Mar 2010
    guildford
    yes the car runs at normal running temp. what could be the prob with the heater???
  7. Re: Is it safe to drive ?
    middlewich uk
    could be the heat control broke are anything, worth getting it looked at before you spend a fortune on cambelt and waterpump
  8. Re: Is it safe to drive ?
    Mar 2010
    guildford
    thanks , how can i check to see if there is another problem. you mentioned about the pipes being hot. i know the pipes did not seem to have any presure in them when i sques them but the car had not been running long at the time .
  9. Re: Is it safe to drive ?
    Feb 2007
    Nottingham
    This could just be a fault in the valve to take water into the heater matrix or an air lock rather than something more serious.
    I would firstly check your header tank and radiator have plenty of water in whilst the car is cold, start her up on your driveway and keep an eye on her whilst running. After ten minutes you should feel the top and bottom pipes from and too the block becoming warm if everything is ok with the cooling system. If this is the case then you know its your heater matrix/valve/control board etc etc.
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  10. Re: Is it safe to drive ?
    Tyldesley, Manchester, UK
    Water pump failed on my old Passat. I drove it carefully to the dealer about 10 miles or so.
    One German, Two Italian.
  1. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  2. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  3. New HDD-Disk Managment -Drive size is displayed as less???
    Last Post: 14-12-2007, 08:45 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. How does the Quattro system work?
