Thread: Plasma Cutter!!
  1. Plasma Cutter!!
    Bratty Guest
    Just borrowed my mates plasma cutter!!!!?!!!! What a ******* tool!! you can cut ALMOST any metal with absolute precision. Its brilliant!
    Dunk
  2. Re: Plasma Cutter!!
    Pembrokeshire
    22 Post(s)
    i really want one, but so expensive. i will justify it one day though. did you know that a gas axe can cut through 7 feet of steel.
  3. Re: Plasma Cutter!!
    Feb 2007
    Nottingham
    Get yourself a gas axe Zollaf, much cheaper and i've never found anything I can't cut with it
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  4. Re: Plasma Cutter!!
    Bratty Guest
    Gas Axe sounds like the perfect tool if your Boss is Michael Caine and you are setting of in a bus to do a Bank Job (without the prospect of "Blowing the Bloody Doors Off"!).
    The Plasma Cutter I find amazing not just cause it sounds like an extraterrestial tool, but because it is so easy to use, and relatively safe. The drawback is price definetely AND! that once purchased you realise that you need an EXTRA! Air Compressor with a Big Capacity (air tank) to feed the unit (which is also not cheap ).
    Dunk
