Thread: engine problem
  1. engine problem
    Dec 2009
    oldham
    hi can someone help as my car audi a4 1.6 8v 98 is limiting at 5000 rpm
  2. Re: engine problem
    1836 Post(s)
    You have a problem with the hall sender G40, a fault code read will give you code “00515 Hall sender –G40” and then a fault type
  3. Re: engine problem
    Dec 2009
    oldham
    thanks pal sorted it now all back to normal cheers
  4. Re: engine problem
    1836 Post(s)
    Was it the hall sender?
  5. Re: engine problem
    Dec 2009
    oldham
    Yeah it was. Good as new now thanks
  1. Engine rev / gear change problem with 1996 cabriolet auto
    By Audi-arrrrrgggh in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 31-03-2014, 08:32 AM
  2. Please Help ***?? - Engine serial removed!
    By TheRealYeti in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-08-2010, 08:06 PM
  3. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  4. VW Golf 1.4 S Engine problem...help.
    By sgx in forum Golf MK4 - 1999 - 2004
    Last Post: 29-02-2008, 01:13 PM
  5. chronic check engine problem
    By jean myrthil in forum Archive posts
    Last Post: 21-02-2007, 05:59 AM
