Thread: 2.5TDi Rocker cover gaskets
  1. Question 2.5TDi Rocker cover gaskets
    Apr 2009
    Just a quick question is it possible to change the rocker cover gaskets on a 2.5 Tdi without disturbing the fuel system. As my fuel system has been a bitch to bleed off when I've taken off the fuel pipes in the past???
    Audi A4 Avant 2.0 TDi 2009
  2. Re: 2.5TDi Rocker cover gaskets
    Aug 2007
    Hook Hampshire
    21 Post(s)
    No. You have to take all 6 pipes off before the covers can cam off, but it should start after a few turns. I have had no problems having done it several times
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  3. Re: 2.5TDi Rocker cover gaskets
    Apr 2009
    In earlier cars they didn't fit a priming pump in the tank. So I end up manually bleeding a few times then having to crack off the injectors to finally get it started.
  4. Re: 2.5TDi Rocker cover gaskets
    1836 Post(s)
    The one I did on Thursday (after fitting new cams) took about 2 minuets of cranking with the pipes cracked off on each injector until fuel came through and then another 30 seconds or so to fire up when they were tightened up.
  1. Car breakdown cover from chris knott insurance
    By Tim@ChrisKnott in forum VW Audi Forum "Preferred" Insurance In association with Chris Knott
    Last Post: 21-04-2011, 09:17 AM
  2. Question Torque settings for Rocker Cover bolts on 1995 Coupe 2.0E
    By Jonnovision in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 26-02-2010, 10:58 AM
  3. Rear Brake light cover fitting
    By warp_speed in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2010, 08:14 PM
  4. Please Help sheared rocker cover bolts
    By DropKickMurphy in forum Golf MK3 - 1993 - 1999
    Last Post: 03-12-2009, 03:28 PM
  5. Question VW LT 35 Rocker Cover
    By rob20087 in forum The Commercial Range
    Last Post: 29-06-2009, 06:19 PM
