Can anyone help
This problem is cuasing me head aches
I am still getting a coolant circuit fault code coming up
(17700) Map controlled engine cooling thermostate-F265
(OPEN CIRCUIT) this I think is making the engine run very rich
I have to date replaced the coolant temperature sensor at the back of the engine and the one that by the rad underneath.
Looking at fault codes on Ross tech it lists I have looked at all of these
all wires look ok that are going to the plug it click when I plug it on
is there any other wires that I need to check.
Any hidden fuses or conections.
17700/P1292/004754 - Map Contr
olled Engine Cooling Thermostat (F265): Open Circuit
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Fuse(s) faulty
  • Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265) faulty
  • Map Controlled Engine Cooling Thermostat (F265) faulty
Possible Solutions
  • Check Fuse(s)
  • Check Wiring and/or Connector(s) from/to Map Controlled Engine Cooling Thermostat (F265)
  • Check/Replace Map Controlled Engine Cooling Thermostat (F265)
