Thread: squeeky wishbone bushes?????
  1. squeeky wishbone bushes?????
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Hi gang,please tell me what I've done wrong.
    Last weekend I changed the front anti roll bar "D" bushes and the wishbone bushes x4 on my '95 2.6 front drive coupe.
    Question is I'm now experiencing a lot of "tight rubber" squeeking and a little bit of clonking when moving off, coming to a standstill and steering when stationary.
    I understand that a lot of you will ask "did you tighten the w/bone pivot bolt correctly?",now because of various supporting /jacking issues I loose fitted the bolts with the front of the car on stands with no wheels fitted,then one side at a time jacked the whole strut as hard up under the wing as possible until the car started to lift off the stands, then fully tightened the pivot bolts.
    The a/roll bar "D" bushes I don't remember if the car was hanging loose or struts forced up.
    Would my method cause this odd affair ,which was certainly not there before I started or have I just highlighted the possibility that the subframe bushes may be shot.?
    I fully intend to replace the s/frame bushes just to know the car is right but have run out of shillings at the moment
    Should I have sprayed wd40 or similar onto the area while fitting to alleviate this noise?
    I know that was a load of "did I ,have I ,should I but I'm quite sure IT HAS ALL BEEN CAUSED BY ME AND I DON'T USUALLY STUFF THINGS UP
    Please give us a nudge and I'll get under her and have another poke about
    Thanks gang
    Stuart
  2. Re: squeeky wishbone bushes?????
    Pembrokeshire
    22 Post(s)
    i think you have highlighted the subframe bushes myself. now the suspension is all tight it will put extra strain on those old bushes. i would get them done and if the squeeking is still there look more closely at the wishbone bushes.
  3. Re: squeeky wishbone bushes?????
    Oct 2009
    10 Post(s)
    I am in agreement,I renewed the w/bone bushes last week.
    The MOT inspector , seemed to think my problem ,as described to him ,was that the small triangular plates that the rear bush bolt goes through,was fitted up-side down but I only re-fitted them the way they were before I touched them.
    (I had to draw the s/f bolt to remove the w/bone bolt)
    None of these odd noises were apparent until I changed the other bushes so I reckon these sounds will clear up when I do the s/frame bushes,hopefully
    Many thanks zollaf
    Stuart
  4. Re: squeeky wishbone bushes?????
    Oct 2009
    10 Post(s)
    All done ,replaced the sub frame bushes today,rebuilt the lot back up, jobs a good 'un
    Thanks to zollaf for the advice and thanks to crasher for the diagram,it turned out that I had refitted two triangular plates upside down last week and thus caused the grinding clonking noise.
    Many thanks to everybody who contributed, she drives a treat now
    Stuart
  1. replacing front wishbone bushes vw polo tdi 1.4 2003
    By robert1z in forum Polo - Derby - Lupo - Fox
    Last Post: 18-07-2010, 12:29 AM
  2. Please Help Front+Rear wishbone bushes need replacing on BORA
    By shagi101 in forum Bora - 1998 - 2005
    Last Post: 10-10-2009, 01:14 AM
  3. Replies: 3
    Last Post: 28-05-2009, 11:17 PM
  4. Polo wishbone rear bushes
    By sbhammo in forum Polo - Derby - Lupo - Fox
    Last Post: 07-04-2008, 09:17 PM
  5. Audi 80 TDi Wishbone bushes
    By andypdq in forum 80 - 90
    Last Post: 01-07-2007, 09:01 AM
