Thread: Flat battery on GT Tdi 140 (55 plate)
Results 1 to 10 of 14
  1. Flat battery on GT Tdi 140 (55 plate)
    Apr 2009
    Rutland
    Has anyone had a problem with flat battery on TDi 140? I left mine sat on driveway for 5 nights and today found that it won't start. I had a similar problem mid Dec 09 and changed the battery (Bosch HD type).
    Is it likely to be an alternator problem and if so what would VW dealer charge for replacement. Any ideas?
  2. Re: Flat battery on GT Tdi 140 (55 plate)
    Leics
    Have you upgraded your radio/cd?
  3. Re: Flat battery on GT Tdi 140 (55 plate)
    Apr 2009
    Rutland
    No, nothing changed at all. I've checked this morning and it seems fine (remote lunlock/lock). It will probably be OK until it sits for another few days.
  4. Re: Flat battery on GT Tdi 140 (55 plate)
    Mar 2010
    wigan
    if you're in the aa or rac they will do a diagnostic for you to check if its charging. could be a dodgy battery, if you got it from halfords they come with 12/36 month warranties
  5. Re: Flat battery on GT Tdi 140 (55 plate)
    Leics
    Could be the alternator.
    See post #4 in this thread:
    https://www.vwaudiforum.co.uk/forum/s...trical+leakage
    Good luck,
    Ron
  6. Re: Flat battery on GT Tdi 140 (55 plate)
    Oct 2009
    oldham
    hi
    put a meter on the battery, it should be around 12.6 ish volts and record it again when engine is running it should go up to 14. something, not sure if its got a smart charging system. If it does, points to alternator working ok
  7. Re: Flat battery on GT Tdi 140 (55 plate)
    Leics
    Try leaving a CD in the radio/cd player.
    Found this on the Honest John website:
    "Battery drain caused by radio. If you don't leave a CD in the player, then it randomly thinks you've inserted one, then decides you haven't, and then switches the radio on. You then find the car in the morning either with with the radio blaring or the battery flat. Even if you switch the radio off before switching the ignition off, this can still happen."
    Let us know how you get on.
    Ron
  8. Re: Flat battery on GT Tdi 140 (55 plate)
    Apr 2009
    Rutland
    Quote Originally Posted by ChicksFan View Post
    Ron
    Still having the same problems. I've left a CD in the radio and this has had no effect. We went on holiday for 2 weeks, came back and it started first time. Left it 48 hours this week (with CD installed) and it wouldn't start but there was some battery power left as the central locking worked and the dash lights came on OK. I'm still confused about this. Any ideas?
  9. Re: Flat battery on GT Tdi 140 (55 plate)
    Leics
    I'm sorry the CD trick didn't solve it.
    My money would be on an alternator fault.
    I think I'd be biting the bullet and having a new alternator fitted.
    No doubt you've seen this thread on here:
    https://www.vwaudiforum.co.uk/forum/s...t=19878&page=2
    Good luck, Ron
  10. Re: Flat battery on GT Tdi 140 (55 plate)
    Oct 2009
    oldham
    hi
    as I said in my previous post, test the alternator, it takes two ticks, you only require a very cheap meter. No point in forking out for an alternator you don't need.
  1. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  2. another flat battery
    By whitevanman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2008, 06:54 PM
  3. Golf GT TDI Mark 5 54 PLate - Battery Drain!?!?!
    By thaidai in forum Archive posts
    Last Post: 17-01-2008, 01:08 PM
  4. A3 Tdi Battery drain mystery!
    By moreski in forum Audi A3 - Archive Topics
    Last Post: 05-03-2006, 10:29 AM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
