Thread: Audi a6 C5 Remote central locking problem
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
  1. Audi a6 C5 Remote central locking problem
    Hi Everyone,
    this morning my remote central locking stop working, when I open car manually with key central locking working fine, then I decide replace battery, no luck, I tried reprogramming key fob - no luck, when I press unlock no respond from car - no flash - no horn, can anybody advise or help what can be wrong... , many thanks...
  2. Re: Audi a6 C5 Remote central locking problem
    Have you tried the other fob. Regards Peter
  3. Re: Audi a6 C5 Remote central locking problem
    HI Peter, yes I tried another two, which I was keepening like spare, for battery and parts, which I know before all 3 was working , now none, I can't find faulty fuse, manual central locking working fine..., I will have look tonight again..
  4. Re: Audi a6 C5 Remote central locking problem
    You will need to find an independant Vag-Cam guy to talk to your car. J429 central locking control unit could be your problem. Regards Peter
  5. Re: Audi a6 C5 Remote central locking problem
    I have Vag-com, I checked for faults everything, no any faults at all, but I will check again...
  6. Re: Audi a6 C5 Remote central locking problem
    Long Shot. Remove Fuse S238 20 amp for 30 seconds and replace it. This could be an aerial problem. You need to identify the exact year, model and engine code you have but the central locking control unit is in a plastic case under the drivers seat so it is worth checking the connector. Regards Peter
  7. Re: Audi a6 C5 Remote central locking problem
    Dec 2008
    B e sure to use a good battery in the key fobs. With good I mean one with a high mAh capacity. Duracell DL3032 is the one with the highest mAh. Even those run out after 3 months in my case.....
  8. Re: Audi a6 C5 Remote central locking problem
    Thanks Lucas,
    I already checked and replaced battery, still no luck..., keep searcing what can be wrong..
  9. Re: Audi a6 C5 Remote central locking problem
    Depends on useage but mine have been in for 3 years never mind months. Regards Peter
  10. Re: Audi a6 C5 Remote central locking problem
    As you said Peter, I will have look afternoon on fuse again, and check connectors under seat...
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. Please Help Octavia- Central locking keeps locking.
    By Mawb in forum Octavia
    Last Post: 27-09-2013, 02:53 PM
  3. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
  4. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
