Thread: Brake pedal hard
  1. Brake pedal hard
    Jan 2010
    kilkenny, ireland
    Hi,just bought an 02 A6 2.0 multironic 2 wees ago..yesterday the brake pedal wet very hard ( twice ) while trying to stop with virtually no braking power.then 2 mins later the pedal returned to normal..Any ideas??
  2. Re: Brake pedal hard
    Mar 2008
    High Wycombe
    Have you checked the plenum chamber for water? It might have corroded the bottom of the brake servo.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Brake pedal hard
    1841 Post(s)
    It certainly sounds like the servo vacuum feed is poor, I think that one has an electric booster pump and this may have failed.
  4. Re: Brake pedal hard
    Best to quote the three letter engine code from the ID label either in the service book or in the spare wheel bay. Regards Peter
  1. Hard brake pedal
    By riels in forum Ireland
    Last Post: 26-02-2010, 03:44 PM
  2. Brake pedal sensor intermittent...
    By JohnW78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2009, 11:43 AM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
