Thread: location of egr valve b6 passat
  1. location of egr valve b6 passat
    Mar 2010
    luton
    Hi can anyone tell me where the egr valve is located on b6 passat saloon????
    my car goes into limp mode every few weeks stating on the vagcom overboost po234 the diesel workshop geezer said its something inside the turbo needs replacing as it keeps getting stuck.
    any ideas
  2. Re: location of egr valve b6 passat
    1840 Post(s)
    VAG-COM only gave you a P code!?
    16618 (P0234) Charge air pressure sensor –G31- control limit exceeded
    The engine code would help but the EGR valve has northing to do with turbo boost control.
  3. Re: location of egr valve b6 passat
    Mar 2010
    luton
    thanks for the reply.
    it says turbo boost exceeded
    as what happens every couple of weeks on the motorway about 70 miles an hour once i start to go uphill it looses power.
  4. Re: location of egr valve b6 passat
    1840 Post(s)
    Yes but what is the engine code? The engine type code, so we know if it is a 1.9 8v or 2.0 16v...
  5. Re: location of egr valve b6 passat
    Mar 2010
    luton
    sorry
    its a 2.0 tdi 140 bhp
    bkp engine code
  6. Re: location of egr valve b6 passat
    Norfolk
    Turbo vanes coked up. Remove and clean turbo. It won't be the vacuum system.
  7. Re: location of egr valve b6 passat
    DSG4ME Guest
    If it helps until Crash gets back, if you take off the engine cover, it will look like a goldy/silver top hat with a black vacum unit and wire pipe coming from it, if it'd been a simple case of the 1.9 turned around it would be at the back on the passenger side, but the oil filer would be right alongside it, but on the 2.0 it's over where the 1.9 egr valve is located, hth.
    If the unit has changed shape since, which they do from time to time I do apologize for the mistake.
  1. Egr Valve - Low Flow, 1.4 Petrol
    By oceanicgreen in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2009, 07:26 PM
  2. Does my 2.5TDI EGR valve need replacing??
    By omniquito in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-08-2009, 05:51 PM
  3. EGR valve cleaning
    By inca66 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2008, 02:48 PM
  4. Replies: 9
    Last Post: 19-01-2008, 07:40 PM
  5. EGR VAlve Shut off
    By VEEDUBYA in forum Passat - Archive Topics
    Last Post: 22-05-2007, 10:35 PM
