Thread: drum to disc conversion
  1. drum to disc conversion
    Apr 2007
    Coventry
    hi there i have a mk3 td which has the four stud drum brakes at the rear. how complicated is it to convert them to discs.
    I am a novice mechanic at heart and would appreciate the difficulty rating as if using the haynes manual.
    Thanks for reading! J
  2. Re: drum to disc conversion
    Pembrokeshire
    22 Post(s)
    if you really want to, you drop an axle in from a car with disc brakes and job done. but, why would you want to ?
  3. Re: drum to disc conversion
    Aug 2010
    Gorleston Norfolk
    let me think why
    better brakes,
    Safer brakes,
    and thats just with the brake compensator
    As said drop the axel out of a disk car, buy new hoses, and a compensator and bushs and your almost there, loads of info over at www.clubgti.com
  4. Re: drum to disc conversion
    Pembrokeshire
    22 Post(s)
    if the op had a car of moderate performance, then it could be justified, but he has a golf diesel, that is at the best of times sluggish. fitting discs to the rear of this will result in the brakes just not really doing anything. the discs will quickly corrode, since there will be no need to brake hard for corners, thus no heat will ever be generated and the pads wont actually wear. on a car like this, that vw have spent more than £1.00 developing, good old drum brakes are more than sufficient and are perfectly safe. in fact, a well serviced drum brake is just as good as a disc brake, the only downside being that they will overheat and fade when used hard. this is why disc brakes were developed in the first place. but, being on the back end of a td golf, they are never going to overheat, unless they are binding. so, fitting discs to this particular car is imho a complete waste of time and money. the effort should be put into servicing the existing drum brakes, and the time left over could be spent polishing it. of course, it is the op's decision, but the original post was a while ago., and it seems 'dubtastic' totally ignored my original reply since he didnt bother to reply to it, which is fine, but a bit rude really.
  5. Re: drum to disc conversion
    Aug 2010
    Gorleston Norfolk
    sorry bud need to learn to read didnt see the oil burner bit lol
    in that case unless its been modded big time drums ftw
  1. Replies: 35
    Last Post: 22-01-2015, 11:12 PM
  2. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  3. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  4. VR6 Disc Conversion for Golf 3
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-04-2007, 09:22 PM
  5. Vento rear disc conversion
    By SV650s in forum Vento - 1994 - 1998
    Last Post: 19-09-2006, 02:31 PM
