Thread: Waterpump and cambelt
  1. Waterpump and cambelt
    Jan 2010
    Leicester England
    Hi All,
    I had a funny squeaking noise coming from the engine which Audi have diagnosed as coming from a faulty waterpump. They will replace it under the warranty.
    A colleague of mine (who has almost exactly the same car as me) said that the waterpump is attached to the cambelt, and that since the car has done 61k I should get the cambelt changed at the same time.
    From what I can work out from searching this forum the cambelt is indeed attached to the waterpump and the cambelt will be removed to replace it.
    Could someone confirm this, just so I am sure?
    Assuming that is the case, will Audi replace the cambelt as a matter of course? Or should I specifically ask for them to do it?
    Since they will be doing all the labour under the warranty to replace the waterpump it seems reasonable that I would only need to pay the cost of the cambelt itself. If so, what would be the price of a cambelt? I can only seem to find the price of replacing them and not just the part itself.
    Many thanks,
    Mark
    A6 3.0 SE Quattro
  2. Re: Waterpump and cambelt
    May 2008
    The cambelt isn't attached to the waterpump. The waterpump is driven by the cambelt, but the belt is (almost fully) removed to access the pump.
    I'd specifically instruct them to change the belt and the tensioner rollers (£100 ish in parts maybe?) Some garages would change it as matter of course but many would not bother - insist they do and ask for the old parts to be left with you.
  1. Cambelt and service bits
    By The-Stig in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-02-2010, 06:31 PM
  2. Replacing Cambelt and Water Pump
    By jonsey24 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2010, 11:44 PM
  3. cambelt questions
    By tdi_geezer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2008, 02:01 PM
  4. MK4 GTTDI PD150 Cambelt and 60K Service
    By xsi in forum Golf MK4 - 1999 - 2004
    Last Post: 01-12-2007, 06:18 PM
  5. A4 avant waterpump and cambelt failure
    By michaelahill in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2007, 01:58 AM
